Removal of Laser Burns on wood Options
Zeptrader
#1 Posted : 16 May 2010 08:17:07
As I got my launch in part 6 I noticed some degree of laser burn, so a quick search around I found some good advice on MSW, linked here -
http://modelshipworld.co...2/viewtopic.php?t=11614
Quote:
I have had a lot of sucess just using a rubber
Quote:
I've seen Windex recommended. Perhaps with a soft toothbrush. Agree with Bob, probably best to test on scrap first.
Of course if your painting then this is not for you Flapper
Feel free to add you laser burn removal tips.
Capt Stedders
#2 Posted : 16 May 2010 10:53:25
A selection of rifflers and needle files seem to do the job quite well (along with a bit of W&D paper to polish things off).
It may be worth noting that before assembling the launch jig (#6) it will be easier (and advisable) to prep the inside surfaces of the formers and planking first (removing laser burn and smoothing the flat surfaces) as trying to get to these areas, once the launch is removed from the jig, will be considerably more difficult once assembled.
just a thought
Schnellboots on back burner
Tools.
