Here it is in Germany....looks a nice kithttp://www.bau-die-black-pearl.de/
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Weekends work is done, half of this deck is completed :-) For information: the planks are 3x1 mm bought coloured on EBay. der Gohfelder attached the following image(s):
Looks good Bernd
Looking good Bernd and I love the colour of the decking....
Mister T. and Alan, thanks for your kind comments! Regards, Bernd
Hi Brent. Comming along nicely. Keep up the good work.Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Bernd, fantastic build, I love the concept of one side being open  thanks for sharing. best regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Ian & Mike, thank you very much for your comments! Now the deck is completed and I have to wait 4 weeks for the next issues...... Regards, Bernd der Gohfelder attached the following image(s):
Yesterday the next issues arrived, "planking" begins. There are some bigger parts with the gun ports inside. In my opinion these parts are too big, I needed superglue to fix them. I´ve also got the first parts for the inside planking, they only should be painted. Of cause I don´t like this and so I made a planking with the same wood I used for the decks. In my first posts I told you, that MDF is used for the frames (correct word???). This material is very bad for nailing! I had to drill for each nail because MDF is too strong to get a nail in it. The surface of MDF has to be sanded, if you don´t do it the glue doesn´t work. Regards, Bernd der Gohfelder attached the following image(s):
Looking great Bernd, coming along very nicely indeed....
Your deck planking looks a big improvement compared with the paper deck overlay provided with the kit
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
der Gohfelder wrote:Yesterday the next issues arrived, "planking" begins. There are some bigger parts with the gun ports inside. In my opinion these parts are too big, I needed superglue to fix them. I´ve also got the first parts for the inside planking, they only should be painted. Of cause I don´t like this and so I made a planking with the same wood I used for the decks. In my first posts I told you, that MDF is used for the frames (correct word???). This material is very bad for nailing! I had to drill for each nail because MDF is too strong to get a nail in it. The surface of MDF has to be sanded, if you don´t do it the glue doesn´t work.
Regards, Bernd
Yes Bernd, it will be M D F. Medium Density Fibreboard. Very hard to work with, Your build is looking good.
Mo. 👏. 👍 Mo
Hi Tom & Mo! Thanks for your kind comments! Let´s wait and see what is coming next Regards, Bernd
Hi Bernd. Looking fantastic. Decking looks the business.look forward to seeing your progress. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian! Thanks for your kind comment! I´m still waiting for the next issues, I think the "real" planking has to be started next :-) Regards, Bernd
Your Build is looking really good  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike! Thanks for your comment! It would be a good kit for you, there are a lot of extensions to be done Regards, Bernd
der Gohfelder wrote:Hi Mike! Thanks for your comment! It would be a good kit for you, there are a lot of extensions to be done Regards, Bernd Hi Bernd, will it come to the UK? kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi! Sorry, I don´t know..... Regards, Bernd
Hi! In the last delivery one part was missing and I could not go on working. Yesterday the missing part arrived and so I had to complete the inside planking of the hull. The "normal" version has only wooden parts which are painted. Of cause I made it like the decks with wooden strips in grey. I think in the next issues ( >32) the outside planking has to be done. Regards, Bernd der Gohfelder attached the following image(s):
