flower class corvette Options
willie
#1 Posted : 19 January 2013 13:52:06
this is a big revell model which i am converting to r/c 850mmlongx150 beam plenty of room
alantait
#2 Posted : 19 January 2013 16:05:57
remember having this model or one similar a few years back, she was a great build with plenty detail, looking forward to your build, kind of brings back memories and might just (if she allows) to go for one again as a static model in between timber builds.
current builds
#3 Posted : 19 January 2013 22:19:04
I bought that kit when i was 15 its big and lots of scope to detail. so it must be at least 23 years old!! Crying Blink
#4 Posted : 19 January 2013 22:30:08
BigGrin Did it come with any etch and will you be adding any m8Cool
willie
#5 Posted : 20 January 2013 12:01:00
yip it came with a etch set fussy about rubbing the eye brows of the hull to fit the eatch ones though also wooden decks which are self sticking which i think will be a bit of fun trying to get them right also brass guns barrels and various fittings like for the mast
willie
#6 Posted : 20 January 2013 12:14:40
#7 Posted : 20 January 2013 12:27:38
Very nice, and loads of detail! I like the PE set you get, and the deck looks lovely, although self adhesive is going to be fun!BigGrin
moriarty
#8 Posted : 20 January 2013 12:43:18
Wow, they have certianly updated that kit. It should be a beauty when its done. The self adhesive deck can be a bit fiddely but if you put some paper on it first and trim the paper to the deck you can then glue it down at leisure, just an idea.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#9 Posted : 20 January 2013 13:30:17
'Ere, that's not fair!
My brother was given this kit from a friend and then passed it on to me. The hull and main decks have been glued together and painted but that was as far as the original owner got.
One day I will give it a go but there's no brass or wood effect decks at all, its all plastic!Crying
I think I've actually got the original Matchbox kit and not the later Revell 'buy out' re-issue. It sounds like they've done a really good job of improving it though.
Best of Luck with your build!Cool
Robin
willie
#10 Posted : 20 January 2013 13:48:14
the deck is pre cut with all the spaces for the other parts to glue on is clear it only where the deck is clear it goes,soCool that helps with the line up
willie
#11 Posted : 24 January 2013 20:56:36
motor and steering now fitted
#12 Posted : 24 January 2013 21:29:22
Hi Willie, I like it very muchBigGrin looking forward to your build Kind regards Mike
willie
#13 Posted : 24 January 2013 22:04:33
cheers mike a bit slow waiting for a battery so i can fit it perment so i dont need to take of the forward deck to much hassel
willie
#14 Posted : 30 January 2013 21:55:49
battery, ballest,and speed controller fitted the battery is permently glued in to hull charging wires will be fitted so i dont need to open up the deck to take it out
willie
#15 Posted : 03 February 2013 21:29:03
decks fitted, wheel house with the reciver the ford gun with the photo etch parts this photo etch parts are made out of steel the only way i have found to cut them from the fret is to use a chisel blade and hit it with a pin hammer
