40 Pages «<2223242526>»
#461 Posted : 17 January 2013 22:38:02
Admiral Anti Spiral wrote:
Hi Alan, its mentioned in issue 11 that 16th-17th century ships usually had the bowsprit set to the right as Mike has stated, i believe it should probably be set to the right as the magazine suggests, though im not sure how this would effect the rest of the build at the bow, good luck with your choices!
Thank you for your inputBigGrin I will offset the Bow sprit, but I will wait untill the very last minuet, to see what else is affected, and see what I will have to modify in order to do itCool Kind regards Mike
yamaska
#462 Posted : 18 January 2013 00:07:42
Mike
If I may impose myself on your blog I have simply some clarification although no definitive answer. The following is a well known picture of SoS and here the artist shows what is referred to as a 'square tuck'
FOR DISCUSSION PURPOSES ONLY
This term refers to manner in which the planking finishes around the stern. A 'Round tuck' is when the planks curve gently round to butt up against the stern post. A 'square tuck' means that the planks finish at more of a bulkhead near the stern and then other planks complete the stern effectively perpendicular to the keel and stern post.
Academic thinking is not wholey clear in the case of SoS since the drawing seems to show a square tuck however this style of ship design was going out of fashion in England in the early 17th century.
To quote some research on the subject:
' it seems fairly certain that the Constant Reformation of 1618 had a round stern; it is quite certain that the Prince Royal of 1610 had a square tuck. In the case of SoS it seems probable....that the artist meant to show a square tuck.'
In my view this tends to support your argument that the stern should be fuller and the planking should terminate as the drawing suggests.
Anyway each to his own choice. I hope this helps with some thoughts.
John
#463 Posted : 18 January 2013 08:13:37
Hi John,
Thank you for your contribution to the debateBigGrin this information is very much appreciated, what is your view about the bowsprit?
Kind regards Mike
Dontshootme
#464 Posted : 18 January 2013 08:23:54
I think you have hit the nail on the head with this one Mike,the square tuck looks right,especially with all that ornate decoration to hold up.Whilst the mag version looks "pretty" as is so often termed about ships lines it definitely does not look right,lines like that are for fast ships,& from the looks of her the sov was anything but fast.
In total agreement with the offset bowsprit as it was common practice wit such forward stepped masts,when it all changed regarding this I leave to the historians.
I shall definitely following this with the strong inteention of doing the same on my build when I get to it(saving it atm).Good luck with the rest of the mod.
court orchard
#465 Posted : 18 January 2013 10:12:41
Hi Mike,
Payne, Eyde and Van de Velde the Elder's drawings show the Stem Head on the side of the Bowsprit, with the Bowsprit then passing on the Starboard side of the Foremast, as you suggest. However, Sepping's model of 1827 shows the Bowsprit sitting centrally.
Ref. Sephton pgs 120-121.
yamaska
#466 Posted : 18 January 2013 12:29:14
Mike
As far as the bowsprit is concerned I have one specific reference which goes as follows:
'Around 1630 (the bowsprit was stepped) at about 20 degrees, around 1650 about 30 degrees..... From the early 16th century until about 1650 (occasionally as late as 1670), the bowsprit was routed past the foremast on the starboard side. It did not lie parallel to the keel, but at an angle, so that the head of the bowsprit was on the centreline of the ship.'
I hope this is helpful. By the way I enjoy your skilled construction and clear build explanations. Bravo
John
#467 Posted : 19 January 2013 08:12:18
Thanks Rob , Andy, Dominic and John for your contributions I will be offsetting the Bowsprit but following the centre line of the stem.
I will do this Modification ay the last minuet so I can see what else is affectedBigGrin Kind regards Mike
#468 Posted : 21 January 2013 21:07:12
THE HULL STERN MODIFICATION
Well Team, I have finished the modification, having fitted the to piecs of wood last time, I now fill in the space with more balsa the photos tell the story:-
#469 Posted : 21 January 2013 21:13:56
The next job was to get a really smooth finish, I did this by sanding and filling, sanding and filling untill I had the required shape and finish I was looking for, :-
#470 Posted : 21 January 2013 21:21:17
The last thing to do was to thin down the Keel to 1mm as this is essential to fit the planks to the correct thickness at the stern (I was very surprised this very important job was not covered in the instructions):-
#471 Posted : 21 January 2013 21:25:08
And here is how she looks now, thank you for looking in, Questions ans comments are welcomeBigGrin
Next time I will cover how to postion and fit the planks on this now modified stern Kind regards Mike
#472 Posted : 21 January 2013 21:49:55
Beautiful piece of work Mike, can now see what you were getting at..... thanks for sharing....
#473 Posted : 22 January 2013 08:27:34
Hi Alan,
Thank you for your nice commentsBigGrin Regards Mike
Dontshootme
#474 Posted : 22 January 2013 09:52:33
That looks so much better Mike,definitely a mod I think I will do when my time comes.
#475 Posted : 22 January 2013 18:35:01
Hi Rob, Thank you for the complimentBigGrin I am sure your build will be great Kind regards Mike
claret
#476 Posted : 22 January 2013 19:19:15
Hi Mike,
Looking brilliant, and tempted to follow you and make the model more authentic, but still learning, and might be a step to far. I will with the official build, but like the knowledge and possible alternatives you bring to the forum.
Claret.
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Admiral Anti Spiral
#477 Posted : 22 January 2013 21:03:02
great work mike! sure makes a greater difference for the better, keep it up!BigGrin
Processing - Progressing
Previous builds: HMS Victory
#478 Posted : 22 January 2013 22:14:58
Hi mike.
Very nice modification looks very nice Ian BigGrin
#479 Posted : 23 January 2013 09:03:08
Thank you Claret,Dominic and Ian for looking in and for your commentsBigGrin your contribution is appreciated Kind regards Mike
Hans
#480 Posted : 23 January 2013 12:46:20
Looking good there Mike. Love the shape. Lots of thought and effort and a fine result, well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
This page was generated in 0.276 seconds.
