40 Pages «<2122232425>»
#441 Posted : 15 January 2013 12:41:17
ISSUES 16/17
Thats all for now, the modification will be covered nextBigGrin thank you for looking in, questions and comments are welcome
Kind regards Mike
#442 Posted : 15 January 2013 17:09:23
THE HULL STERN MODIFICATION
Hi Team I have arrived at this Mod through looking at the way the hulls of ships are formed I am going you show you photos of three of the ships I am building, so you can see what I want to achieve with the SOTS:-
1) The ENDEAVOUR, the planking sweeps up to meet the stern cross planking
#443 Posted : 15 January 2013 17:14:08
2) THE VICTORY
The planking also sweeps up to meet the stern crossplanking:-
#444 Posted : 15 January 2013 17:22:52
The final ship is the
3) SAN FRANCISCO 2
This is a ship that predates the SOTS, THE VICTORY and THE ENDEAVOUR, but it does not have a shallow stern hull, and you can see the side arch shape, which is shown on the poster of the SOTS, which I want to recreat
#445 Posted : 15 January 2013 17:27:16
THE STERN HULL MODIFICATION
I was not happy with the shape of the SOTS stern hull in my opinion it is too shallow:-
#446 Posted : 15 January 2013 17:40:21
That is how I came to want to change the Hull shape, next time
I will cover next time how I started to modify the SOTS.
Questions and comments welcome Kind regards MikeBigGrin
#447 Posted : 15 January 2013 22:33:30
Nice work as usual Mike.... For me, as this is my first build I do not intend to deviate too far from the official build... think I need to build up experience before I tackle modifications of this kind..... thoroughly enjoy your tutorials though.... thanks....BigGrin BigGrin
#448 Posted : 15 January 2013 22:47:22
Hi Alan, always do what your comfortable withBigGrin you are doing a very good job of your build. Kind regards Mike
Hans
#449 Posted : 16 January 2013 09:16:52
Hi Mike
Good looking job so far. Interesting approach to the look. I am not doing the SOTS yet, not yet released here in SA, but understand where you are coming from and must agree. Keep it up, plenty folk will be watching and following you. Will be following with interest.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#450 Posted : 16 January 2013 10:45:15
Hans wrote:
Hi Mike
Hi Hans thank you for the encouragement,BigGrin much appreciated Kind regards Mike
court orchard
#451 Posted : 16 January 2013 12:07:59
Intriguing modification , Mike. I am interested to see how it develops.ThumpUp
Admiral Anti Spiral
#452 Posted : 16 January 2013 13:34:00
Glad to see more from you mike, sounds like a good modification you got going there, cant wait to see more!
Processing - Progressing
Previous builds: HMS Victory
#453 Posted : 16 January 2013 20:14:51
Thank you for the interest,BigGrin it has proved to be an interesting project, and has put some balance into the hull stern. Regards Mike
#454 Posted : 17 January 2013 13:31:31
THE MODIFICATION OF THE HULL STERN
Hi Team the first thing I did was take measurements from my other models and came up with a size which I thought was acceptable.
The balance of the keel had to be my priority, I prepared 2 pieces of Balsa wood (6mm thick)in a triangle shape 6cm x 4cm x 1cm,and fitted them 3mm back from the stern cross section planking. These are the Photos of this Stage, more to come later Kind regards Mike
#455 Posted : 17 January 2013 14:11:39
Hi Mike,
Look's good,nice work you can see the difference you got me thinking about mine.
kind regards Trev.
court orchard
#456 Posted : 17 January 2013 14:52:03
I agree, that looks better already. I've been troubled by that lower stern profile, plus the sweep that the planks would have to take, for some time. Your modification looks like it could well be the answer. Looking forward to moreThumpUp
#457 Posted : 17 January 2013 21:22:21
tf64 wrote:
Hi Mike,
kind regards Trev.
Thank you Trev your comments are appreciatedBigGrin Kind regards Mike
#458 Posted : 17 January 2013 21:43:27
Thanks Andy, I am able to do the mod easily because of the balsa infills I fitted to the Hull.
I will put these questions to the Team:-
1) Where does it tell you in the instructions to thin the keel on both sides of the bottem stern edge. My calculations estimate the Keel should be no thicker than 1mm to accomodate the plank thickness either side of the Keel of 2mm we also have to fit the second planking on top, an interesting challenge?
2) If we fit the Bow sprit (not the Stem) in the centre, it would hit the foremast, I believe it should be fitted to one side, therefore missing the foremast.
On ships of this era the foremast was fitted very much closer to the bow,and the Bow sprit offset, than ships that came later.
On my Model of the SAN FRANCISCO 2 the Bow sprit is offset. I would suggest a `Starboard` (right) offset, what do you all think?
I have other observations which I will share with you as the build goes on. you comments on the above would be appreciated
Kind regards
Mike
PS more photos of the Hull Modification tomorrow.
#459 Posted : 17 January 2013 21:49:48
Hi Mike, your knowledge and experience is certainly coming to the fore and giving lots of food for thought to us lesser mortals.LOL LOL .... Interesting facts about the offsetting of the bow spirit and yet in all the diaries I have read on this forum it is the first time i have seen it being mentioned... Just goes to show the wealth of information one can obtain in this forum..... Thanks for sharing...
Admiral Anti Spiral
#460 Posted : 17 January 2013 22:30:22
Hi Alan, its mentioned in issue 11 that 16th-17th century ships usually had the bowsprit set to the right as Mike has stated, i believe it should probably be set to the right as the magazine suggests, though im not sure how this would effect the rest of the build at the bow, good luck with your choices!
This page was generated in 0.264 seconds.
