OIL AND VARNISH FOR THE VICTORY Options
IAN
#1 Posted : 14 May 2010 11:03:32
WANTING TO KEEP THE NATURAL WOOD LOOK...
WHAT TYPE OF OIL AND VARNISH WILL BE BEST FOR THIS WORK?
REGARDS,
IAN
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Collingwood
#2 Posted : 14 May 2010 11:24:13
Rank: Newbie
Groups: Registered, registriert
Hi,
I have decided to varnish the "Victory". Although some smaller parts may be marked they can be touched up and then varnished. A clear varnish is all you need as the material is already coloured. I will be painting the mast head etc, to emphasise these areas. This is the first wooden model I have made (I tend to work in plastic). Talking of which - have you heard about the 100th scale Airfix/Humbrol (model #11999) produced in 2005 and if so can I get hold of one?!
Best of luck with your model making.
Simon
willz
#3 Posted : 14 May 2010 13:38:04
the 1/100 victory you discribed is the original 1/100 heller, it comes up on ebay now and then, Karl113 posted this link
http://modelshipworld.co...B2/viewtopic.php?t=8453
although it looks like a lot of scratch building went into it
benny
#4 Posted : 14 May 2010 20:16:42
ian,i may be telling you something you already know,but make sure if your using oil based varnish your first 2 0r 3 coats should be thinned with white spirit,as i work in this field when i varnish wood for the first time my first coat would be 50% spirit and 50% varnish,then 75% varnish and 25% spirit and so on..it acts as a primer and has penetrated the wood..neat varnish would just sit on the top and could peel in the future..hope this helps
cheers benny
Zeptrader
#5 Posted : 15 May 2010 18:51:50
Nice advice Benny, I made sure before staining is to try it out on some scrap wood first.
I used mostly Beeswax and danish oils, worked well on my Bounty.
