Rib Frame 26 Options
jdknole
#1 Posted : 26 December 2012 21:21:15
Rank: Newbie
Has anyone experienced alignment problems with Rib Frame 26? Whilst attempting to fit the last of the 3x13 strips as per Issue 12, I have ended up with a gap of some 3-4mm between the top edge of the strip and the first deck supports on Rib Frame 26. This is unlike all the other rib frames where the strip fits quite snugly.
This suggest that there is a problem with that rib frame. Grateful for any tips or suggestions.
I have attached a photo of the rib frame concerned. I have marked it up showing the distance between the deck and the first deck support on rib 26 (marked as B) and rib 22 (marked as A). You can see that B is noticeably bigger than A resulting in a gap once the 3 x13mm strips are fitted. I hope this makes sense now.
#2 Posted : 26 December 2012 22:08:50
JD, would be helpful if you could post a photo of the problem. This would help others give you the right guidance......
jdknole
#3 Posted : 27 December 2012 11:55:10
Rank: Newbie
Yes that would be a good idea but I can't find any instructions on how to upload images to this forum
jdknole
#4 Posted : 27 December 2012 11:59:33
Rank: Newbie
Cancel my previous, I have amended my original post with a photo.
#5 Posted : 27 December 2012 12:15:43
nothing wrong there,checked mine and is the same.
Aldo
#6 Posted : 27 December 2012 14:04:47
Mine is also the same
benny b
#7 Posted : 27 December 2012 14:16:48
mine is also like this
Admiral Anti Spiral
#8 Posted : 27 December 2012 16:11:25
decks usually rise at the stern
Processing - Progressing
Previous builds: HMS Victory
Pseudo Nim
#9 Posted : 13 January 2013 12:14:31
I wish I'd read this first, I spent all last night taking everthing apart only to re-assemble and find the same thing. Cursing The only possitive was I had to go and find my vernier which had gone missing for several years. BigGrin
#10 Posted : 13 January 2013 13:11:55
hi Pseudo Nim,this has been pointed out by several diary's,please take a little time to scan some of the very comprehensive diary's that forum members contribute regularly to.it does point out any discrepancies that crop up.also the official build that is updated weekly.good luck and enjoy.
#11 Posted : 14 January 2013 23:52:17
Excellent advice Karl, this site is full of useful tips, advice and warnings of pitfalls.... all good stuff for builders who want this build to be a success.... I for one am forever reading other diaries and am still amazed at the standards I see..... Pseudo, hope you will take the advice given.....Cool Cool
This page was generated in 0.135 seconds.
