planking inquiry Options
Admiral Anti Spiral
#1 Posted : 21 December 2012 18:03:47
Im just curious, unless i've done something wrong, how do the planks between the gun ports (green)stay in place? seeing as they're not nailed there, should i of glued the sides of the planks together?
(image from italian forum)
Processing - Progressing
Previous builds: HMS Victory
#2 Posted : 21 December 2012 18:10:13
you do indeed have to glue the sides of the planks together,and take great care when you cut out the gunports,although I believe there will be ply sides on the sots,with gunports already cut out which will make the planking easier.that is why you shouldn't go steaming ahead with these part builds,I tend to be two to three weeks behind when I get to the planking.
Admiral Anti Spiral
#3 Posted : 21 December 2012 19:58:53
Thanks Karl, i thought that might be the obvious solution, the bamboo planks seem pretty tough to cut through, i think i'll be using super glue to hold the planks together. thanks for the reply :)
#4 Posted : 21 December 2012 21:20:30
You must glue each plank to the next plank as well as to the frames, which is mentioned in the official build..
Admiral Anti Spiral
#5 Posted : 21 December 2012 21:40:02
ah i see, i had a look at the official build i guess i missed that part. Thanks for the advice dominic, i think i'll take it and used wood glue instead. As a note, i haven't made any decisions which aren't fixable :).
NMBROOK
#6 Posted : 22 December 2012 07:47:42
ADMIRAL
I would be eternally gratefull if you could tell me how you enlarge the pictures from the italian forum i'm not brilliant on computers and have tried with no success.
Regards Nigel
budgie
#7 Posted : 22 December 2012 08:03:10
BigGrin Mornin' NMBROOK
If it is a web page to enlarge text, pics etc (zoom in)
hold down "CTRL" key and press the "+" key
to zoom out "CTRL" and "-"
BigGrin Hope that helps (unless you have a Mac)
#8 Posted : 22 December 2012 09:10:46
A gentle reminder., if an image is not your property, then you must seek permission from the image owner BEFORE copying such images into this forum.
Thankyou
court orchard
#9 Posted : 22 December 2012 12:09:48
Thanks Budgie.
A good tip, which if I ever knew I'd forgotten.
NMBROOK
#10 Posted : 22 December 2012 18:10:32
Thankyou Budgie will use that alot now.Unfortunately the dimensions were blurred when enlarged.Last time I tried to download the instructions the computer wouldn't let me but tried again last night and no problems,I have updated my laptop inbetween so that must have done the trick.
Regards Nigel
Admiral Anti Spiral
#11 Posted : 22 December 2012 19:18:05
The way i did it was open it in photoshop, i didn't acutally zoom in, i cropped it because the images are pretty big, but yeah if you download the images they're much much clearer :)
This page was generated in 0.190 seconds.
