20 Pages «<34567>»
Admirals HMS Sovereign of the seas adventure Options
#81 Posted : 19 December 2012 23:35:23
Coming on a treat there Admiral..... planking next, that should get your frustration levels up.....LOL ... Keep up the good work..
Admiral Anti Spiral
#82 Posted : 21 December 2012 21:41:57
ahah thanks, planking has always been a bit of a bother, but also fun watching the ship take shape :)
Processing - Progressing
Previous builds: HMS Victory
Admiral Anti Spiral
#83 Posted : 29 December 2012 00:56:07
So we move on to planking of the hull
I've made a small change, i added some support to certain areas, just because if the wood is harder to cut in those places i dont want the strip to fall back into the gun ports, the support isn't perfectly fitted but thats okay it will stay where it is and does the job. Layed the planks in place, left the nails in place at some ribs, i used brass nails so they'll be easy to file down.
The Stern under the galley looks a bit messy, had problems with the filler but i've gotten some new filler now, but i assure it you it is very smooth.
I've moved onto some lighting, 3mm orange LEDs placed around the ship with a 9v battery, possibly more areas too.. there's going to be a lot of wires.. and soldering is very testing to do but it should look great if it all works out. Updates soon.
#84 Posted : 29 December 2012 10:13:55
All looking very good there Admiral... nice work..
Admiral Anti Spiral
#85 Posted : 29 December 2012 20:03:11
Thanks very much Alan :)
Admiral Anti Spiral
#86 Posted : 29 December 2012 20:13:03
Update on part of the lighting ive installed into the ship, the lights should be able to be seen from the third deck gratings, i've also realised other decks will have gratings which i may also add lighting too, i may draw up a diagram of places i'll be adding LEDS too, i dont think theres much need for fiber optics unless i choose to light lanterns.
This is the look so far.
The wires stick out a bit but its not a big problem i'll just have to sand down certain parts of the underside of the third deck. LEDS look a bit bright but thats just the camera, its a fair intensity, not too low but not too high either. soldering is a pain, but if its somewhere where it wont be moved around it should work with only a bit of solder. thats all for now, thanks for viewing :)
#87 Posted : 29 December 2012 23:09:35
Now that's impressive Admiral..... nicely done.Drool . Could you not notch the deck supports to accommodate the wiring, then brace them from below to give them the support they need..... This would prevent you having to sand or notch the underside of the decks...Cool Cool
Admiral Anti Spiral
#88 Posted : 29 December 2012 23:21:24
Oh i did, but when i put the wires in place it looked like it was low enough in, it only sticks out by maybe 1mm or less, it shouldn't cause any problems but it would be preferable if it was perfect BigGrin
#89 Posted : 29 December 2012 23:23:58
BigGrin Hi AAS
there is a guy lighting his vic and he made a framework that the wires are hidden in just an idea and if you've already seen it then you will know what im talking about
#90 Posted : 30 December 2012 00:01:16
Admiral, the vic diary Andy is talking about belongs to 'Bameraam'... Think you would find this one helpful and impressive.... Hope this helps..
Bazas
#91 Posted : 30 December 2012 11:00:58
Rank: Amateur Level 1
Admiral Anti Spiral wrote:
Issue 13
Parts for the ships launch
Metal parts
Wooden parts
Stuck the parts to some white tac, before that i put the oars in a wooden 'jig', simply cut some gaps in a strip of wood and stuck them in. Glued the handle of the bucket to a tooth pick to paint.
Same with the anchor, used some tweezers and a tooth pick
(apologies for the blur)
Hi, Your build looks fantastic, What shade of brown are you using for the oars and bucket.
Thanks Baz
Admiral Anti Spiral
#92 Posted : 30 December 2012 17:15:54
Thanks guys, i've had a look at Bameramms diary in the past, its very impressive and useful :) the wires will shouldn't be visible, though im not sure which side i'll want the wires sticking out, if i even choose to have them sticking out, might be possible to build some kind of housing for a battery on the side of the keel, im sure its possible just some designing and thinking will be needed BigGrin
Admiral Anti Spiral
#93 Posted : 30 December 2012 17:17:18
Thanks bazas, im not particular sure on the name, its a kind of leather colour from humbrol Matt 62.
Bazas
#94 Posted : 30 December 2012 18:25:54
Thanks
Admiral Anti Spiral
#95 Posted : 03 January 2013 22:26:38
Update on lighting.
I've build a small area to hold a 9v battery, its nothing special, just to keep the battery in place using some spare parts.
I've made this battery area here because it will be barely visible when the boat is sitting flat, im not sure if i'll try and cover the area with some kind of hatch or removable cover but once the lower hull is planked (leaving a gap for the battery) it will be very hard to spot.
I've left the wires here exposed which i will later try and cover with hot glue or just some kind of filler, so that if i want to add more lights later i can simple connect it to the spots.
But now i've come across, something which isn't a big problem but would be preferable if there was another way, im thinking about adding a switch because taking the battery out a couple times or simple disconnecting the battery might be a pain, any ideas on where i could add a switch?
im not really a big fan of wires sticking out.. though seeing as the base is pretty flat it might be possible to have a switch sticking out barely visible.
Admiral Anti Spiral
#96 Posted : 04 January 2013 17:15:48
Side planking is done for now, will carry on moving down when more information is available on how, though i dont think it matters how you lay the planks, as long as the finish is smooth outer shell, i've seen in the italian forum they simply lay the bamboo strips as they are, quite impressive. though for now i will be starting from the base up.
Front shot, planking is slightly 'clinker' but it should be fine when sanded down and filled.
Here are some shots of the back with the lighting, lighting seems a bit strong though we'll have to see when we get more of the parts, if it is too bright i'll have to get some translucent material and cover the areas (for example galley windows)
#97 Posted : 04 January 2013 18:58:32
Well done and looking really good Cool
#98 Posted : 04 January 2013 22:05:23
Progressing very nicely Admiral, really starting to take shape now....
#99 Posted : 04 January 2013 22:08:58
Hi Admiral looking great!
I was thinking about your adding a switch problem, I have no idea of the deck layout on the Sovereign but I wondered, does she have a capstan on the main deck? if so you could fit the capstan axle with a thin brass bolt down through the deck with a brass contact arm underneath and a couple of wires to your battery. Turning the capstan would then be able to turn the lights on and off.Cool
Best of Luck
Robin
#100 Posted : 04 January 2013 23:55:44
BigGrin Nice work on the plankingCool
20 Pages «<34567>»
This page was generated in 0.254 seconds.
