First deck location( may be late-just received) Options
#1 Posted : 19 December 2012 17:32:00
Hi allBigGrin
Sorry if this point has been covered, but not found it if it has.
Just done a dry fit of the first deck pieces.Had to make some very minor adjustments to the rib slots and everything seems ok. Except one little issue:having shone a torch into the mast holes it looks like the holes in the deck for the masts are slightly out as well.
Is the solution a very minor enlargement of the holes and if so will this cause problems with the stability of the masts at a later stage.
I don`t want to end up with the mast holes out of line, only to find out it will be to late to do anything about it.Confused
Delboy
Derek
This page was generated in 0.143 seconds.
