issue 16 Options
marls
#1 Posted : 19 December 2012 15:56:34
HI has any one come across a problem with this part of the build? When fitting the deck piece the other parts spring open as though they mite be an issue with the parts
court orchard
#2 Posted : 19 December 2012 16:31:15
Hi Marls,
I found I had to lengthen the slots in the deck extension piece, in order for it to fit over the tabs on the half ribs. It was only about a millimetre on each side, which I did easily with a file.
marls
#3 Posted : 19 December 2012 16:42:29
HI thanks for reply
Mike Smith
#4 Posted : 19 December 2012 16:45:07
Rank: Beginner Level 3
Court Orchard...............do you know how I can access Mr T's S O T S Build Diary ?
Mike
jonny7england
#5 Posted : 19 December 2012 16:56:18
Hi Mike...Just go to the HMS Sovereign of the Seas section and click on Official HMS Sovereign Of the Seas Diary underneath the heading...Hope this helps?
court orchard
#6 Posted : 19 December 2012 18:08:46
Mike
Hi Mike,
Go to the top of this page and click on the Green heading >>HMS Sovereign of the Seas>>, then select Sub Forum 'Official HMS Sovereign of the Seas Diary' and select which section has the issue you are interested in e.g. 16-20
