Looking Great tis keep up the good work. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Late again, same problems. Thouht it was about time I gave you a update. Am up to Issue 91 at the moment and here I had finished the chainwales  Have decided to paint the gallery and not leave it black, there is a error on the stern, I found that the trim either side was too narrow so had to shave a bit off and then found that the cast mouldings wouldn't fit in the right places so juggled them around   I completed the Bowsprit without any problem and have finished the spars,   The area around the stem needs to be tidied up and the paint touched up  Have fitted the port Carronade and what a fiddly job that was   The pictures are not sharp I'm afraid, difficult to get close up with it, need to upgrade to one with macro  That's it for now folks, will endevour to post more frequently in future. Next to do are the catheads and eking rails. TIS
Well done Tiz
Good to see that you are still hanging on in there and going along at your own pace.
Hope you have good Xmas and all the best for 2013, and don't leave it too long before you pop by again..
Hi Mate nice to see a Post from you. Your making great progress She looks really good. Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Tis Glad to see you've been soldering on at your own pace and a very fine example your making there,keep up the good work regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 16/07/2011 Posts: 165 Points: 457 Location: South Wales
She's looking fab Tiz. Gaz Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
That`s really looking very good Tis
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! A nice build, respect! Regards, Bernd
Thanks for the encouraging comments lads. Onwards and upwards as they say. Have started on the Catheads today, cannon balls in shotgarlands then the belaying pins for the starboard side. Will try and post more frequently. TIS
Hi tis. Really great build. Keep up the good work. Look forward to seeing some more of your build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
