 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
What wood were the Victory barrels made from?
I am going to stain one and paint the other to see which I prefer.
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! I think oak will be OK. Regards, Bernd
Hi RobT I think Bernd's right, oak will be fine for the majority of the barrels, I've only got a couple of coloured pictures of the barrels in my reference books, the big things down in the main hold for the food storage are a very dark oak colour whilst the smaller powder barrels in the magazines and around the cannon are a much lighter colour, almost like pine or beech. It's possible though that these 'display' barrels might be simply modern replicas without the 'ageing' patina of older wood. Best Wishes Robin PS Sorry the photos aren't better, I had to photograph the book itself, it was too big to get on the scanner! Plymouth57 attached the following image(s): First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Thanks both. I've got some dark oak stain, I'll have a try.
maybe the barrels were made from different woods depending on the use they were put to. if the powder barrels are lighter they may have been made from a cheaper wood. i would assume that barrels for food or liquid would have to be made from a wood that would not flavour or taint the food or liquidas much. i suppose oak would also be much stronger and harder which may help against rats eating the contents. Come on you Jimmies
I did mine in oak. BarrelsJohn
Oak is a good base but if you look through some of the pics I put up for the cross section you will se a variety of shades due to ageing. It is easier to weather a painted barrel than a stained one. Somewhere in the build discussion is a thread called perfecting the barrel, you may find that helpfull “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
link to Perfecting the barrel http://forum.model-space...aspx?g=posts&t=1339
jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi all barrels were the universal way of transporting goods up until the container system used now was invented by a british lorry driver.One thing that was done aswell is that when a barrel was emptied it could be broken down to its component parts and stored flat until it was needed again thus saving space Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The X section barrels are quite different from the Victory ones. Here's one I stained earlier.
Hi! The barrel is really realistic, well done! Regards, Bernd
