Sloppy fit Options
Bob Abell
#1 Posted : 14 December 2012 20:17:24
Hi Chaps
The tenons on parts 34 have about 1.5mm lateral clearance in the mortices in part 44
What do I do about this please?
Bob
denissimo
#2 Posted : 14 December 2012 20:30:25
Mine was exactly the same Bob.
I dry built the whole section, and then glued them into the correct position.
Then I filled the little gap with a small bit of scrap wood.
Model boats built so far:-
Billings Cutty Sark
Scratch built twin IC RC Vosper MTB.
Scratch built rc electric hybrid.
Scratch built rc IC hydrofoil (ran happily on snow as well as water!)
Plus numerous numerous RC planes.
Under construction
Sovereign of the Seas!
1200:1 HMS Victory (by Mantua)
The Battleship Yamato (seriously considering building as an RC model)
Bob Abell
#3 Posted : 14 December 2012 20:36:05
Thank you, Den
Can you tell, which way the clearance goes?
Bob
denissimo
#4 Posted : 14 December 2012 20:42:47
Off the top of my head no,sorry.
I cant even look in there now to check, as I have done all the planking and cant see it anymore.
It only takes a min or two to figure out when you assemble the whole unit.
Den
Billings Cutty Sark
Under construction
denissimo
#5 Posted : 14 December 2012 20:46:04
Now then Bob, if you look on Mr T's official build, you will see that his was exactly the same, and the positioning that he used.
Den
Billings Cutty Sark
Under construction
Bob Abell
#6 Posted : 14 December 2012 20:55:15
Thank you, Den
The pre assembly sorts out the clearance problem quite easily, so my question is irrelevent now
Thanks a lot.....Bob
mark 2
#7 Posted : 14 December 2012 22:17:31
Hi Everyone.
The clearance in question is so you have got adjustment for everything to be square and in line.
I dry fitted mine and it came out spot on and no filler pieces needed BigGrin .
Best regards all.
#8 Posted : 14 December 2012 23:49:48
Hi Bob, the one thing I do before I do anything on my build is follow very closely Mr T's official build diary... he highlights very well some of the problems we are likely to encounter..... Strongly recommend to follow his build.... For me, it was exactly the same however, I am finding my struts no 45 have the small gap at the bottom of the gallery and not the top. As long as everything is square then you will find it will fit together nicely.....Mellow
Bob Abell
#9 Posted : 15 December 2012 08:24:02
Thank you, Alan
I do follow Mr T`s progress very often, and I only have a small gap on item 45......About 0.020"
Bob
saintsman123
#10 Posted : 15 December 2012 10:23:17
again you seem to be trying to stir something up about the quality of the model. as i have said before there will always be some problems with a mass produced kit.
not everyone building this is an expert, for lots of people this will be the first kit they have ever made, there must be a bit of wiggle room so that those without experience, and without a lot of tools can build a nice model.
i chose the word nice on purpose, as there are a lot of builders on the forum, including me, that just want a nice finished model, at the same time there are people who have been building for many years who will alter parts or source new parts to ensure their model is the best it can possibly be.
from what i can gather bob, you seem to be a very experienced model boat builder, so surely with your experience you can get around the very small 0.02" clearence problems without constant critisism of how the model is designed. you could do what a lot of people do, stop building, keep collecting, and find out what problems there may be in the future, so that you are prepared for them and will know what to do to sort them out.
Come on you Jimmies
#11 Posted : 15 December 2012 13:39:31
seems to me me mr.abell with your list of builds you should be well use to sloppy joints,and in your case I think you have an agenda of general moaning and constant jibs,sorry pal but we don't want to hear them,just put up and shut up,or go back to your build list and give them a good dust,(if you can find them)
willie
#12 Posted : 15 December 2012 16:08:37
the wood needs a clearance to get the wood glue in you can not get glue in to a tight fit it will scrape it off
Bob Abell
#13 Posted : 15 December 2012 16:44:38
I think my thread title of "Sloppy fit" has mis-lead some of you chaps into thinking that I was offering criticism of some sort
I was referring to the lateral clearance in the mortice and tenon and is my way of describing a loose fit
My reference to the clearance of only 0.020" was actually praise!
Bob
#14 Posted : 15 December 2012 17:53:48
Hi Chaps
Bob
Bob
im sorry but it comes across that you revel in posting stuff like this to stir things up and this isn't the 1st time, now that people have said something your trying the Mr innocent tack, as has been pointed out in another post you seem an experienced builder with your list of completed models and the posts are something a compleat beginner would ask and should be easy to sort if you have any experience at building these models
This page was generated in 0.190 seconds.
