40 Pages «<2021222324>»
#421 Posted : 14 December 2012 10:29:55
yamaska wrote:
Mike Your work is consistently accurate, neat and an example to follow.
John
Hi John, thank you for your nice commentsBigGrin Kind Regards Mike
Jesus-Belzheim
#422 Posted : 16 December 2012 04:32:43
Hi Mike
That realy looks very good ThumpUp
Here in Germany there still is no S.O.S. in sight
But this Week I`ve received the first Issue of the Cross-section BigGrin
And thank you for your best wishes,
Wenn I take enough aspirin it`s OK BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#423 Posted : 16 December 2012 09:13:56
BigGrin Hi Mike
Coming together nicely Cool
#424 Posted : 18 December 2012 02:51:36
Jesus-Belzheim wrote:
Hi Mike
Hi Peter Fantastic you are doing the cross section, you will really enjoy itBigGrin Hope the teeth are getting betterLove Kind regards Mike
#425 Posted : 18 December 2012 02:52:42
arpurchase wrote:
BigGrin Hi Mike
Hi Andy thank youBigGrin Bestwishes Mike
#426 Posted : 21 December 2012 17:27:11
MWG wrote:
ISSUE 11 BUILD
I sanded the edges of the decking, and followed the build instructions, plus Mr T`s official build and fitted the deck.
I had pins available so I used them I would not fit decks without the pins anyway.
Because I was careful with my measurements when I fitted the Balsa infills the decks went down without any trimming.
I used the correct size dowel to imitate the Mast, so it was an exact fit.:-
Hi mike,
Sorry this is a bit behind the times but part delivery times not goodCursing .
I have had to make very minor adjustments to the rib slots on the first deck and then to the mast holes. Do the masts get supported by these decks or does the rigging give the masts their main stability.
Your ideas on this would be gratefully accepted.
Delboy
By the way, lovely watching your build, it helps us newbies no endCool
der Gohfelder
#427 Posted : 21 December 2012 19:48:34
And one more time I only can say you make a perfect job!ThumpUp
Regards, Bernd
claret
#428 Posted : 21 December 2012 22:28:12
Hi Mike,
Looking really good!
Total respect!!!!
Claret.
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Jesus-Belzheim
#429 Posted : 29 December 2012 15:19:30
Thank you Mike, and yes my teeth are getting better BigGrin
Kind regards
Peter BigGrin
Jesus-Belzheim
#430 Posted : 03 January 2013 18:42:34
Hi Mike
I wish you a happy newyear
Kind regards
Peter BigGrin
#431 Posted : 04 January 2013 11:24:40
Hi Mike
Hi Peter that is an MEGA greeting thank you so much, and of course the same to you.BigGrin I am back now after a very busy time.
I need now to catch up on the Hood, Victory, SOTS and others.
Thank you to all my friends on the Forum for all their festive greetings, I wish every one of you A VERY HAPPY AND PROSPEROUS NEW YEAR TO YOU AND YOUR FAMILIES
BEST WISHES
MIKE
#432 Posted : 06 January 2013 19:32:46
Hi Mike
A happy new year to you and your family. Looking forward to following your builds over this year.
#433 Posted : 14 January 2013 19:56:48
Hi Team,
I am back after the Festive break.
I have not been happy with the shape of the lower hull stern, and after carefull investigation I have modified this section of the Hull.
I realise there are no real plans and it is left to interpretation, but if you look at the poster we received there is a photo of the doner ship with the shape of the hull stern more in keeping with how I believe it should be, if you look at the photo of the ship in the centre of the poster, I believe the hull stern is too shallow, and would not have displaced the water to support the weight of such a heavy ornate rear hull.
I have studied lots of pictures of ships of this period and come up with a modification that I am happy with therefore it is my interpretation.The planking when it reaches the rear will in my opinion connect with the stern of the ship far more realistically than before the modification,I will also be extending my side planking past where it is shown in the instructions in order to achieve the arch feature at the stern of the ship.
More to come
Best wishes
Mike
I will be posting photos of my mod, for those of you who are interested from and including ISSUE 16
#434 Posted : 15 January 2013 00:10:53
Nice to see you back Mike, look forward to seeing pics of your mods....
#435 Posted : 15 January 2013 11:30:33
Hi Alan thank you for your kind words, my business has kept me very busy, but I am not complaining it is usual for the work to drop off in January / February but not so far, lets hope it keeps up eh!BigGrin Your builds are looking very good, you should be proud of yourselfCool Kind regards Mike
court orchard
#436 Posted : 15 January 2013 12:18:30
Mike, I don't know how you do it!Confused Confused Confused
By my count you have 14 ongoing and uncompleted builds with extensive build diaries and I notice you've been putting your hand up for all the new DeAg models coming out this year. Not only that, but you add loads of extras and modifications to all your builds. I assumed you were retired with a lot of time on your hands.
Now, I can only assume you do not sleep at allLOLLOL
Two models at once is really one more than I can find time for and run my business.
#437 Posted : 15 January 2013 12:19:55
ISSUES 16 and 17
Hi Team, I have combined 16/17 together for ease.
I have followed the intructions in the magazine and kept abreast of MR T`s official build, where I have deviated from the plan is to again fit balsa infills and then Modified the stern hull.
The photos should tell the story:-
#438 Posted : 15 January 2013 12:26:11
ISSUE 16/17
At this point I added the balsa infills and fitted further balsa in the rib 27 assembly:-
#439 Posted : 15 January 2013 12:32:40
ISSUE 16 and 17
Its time to do the rear planking, I have ditched the bamboo planking in favour of lime wood, I bevelled all the edges so that the planks would all sit together correctly:-
#440 Posted : 15 January 2013 12:37:43
ISSUES 16/17
Now a little more balsa up the sides of the rib 27 assembly:-
Guest (5)
This page was generated in 0.336 seconds.
