21 Pages «<34567>»
Karl's Sovereign of the Seas Options
#81 Posted : 12 December 2012 18:19:28
no tom,it's not yet stuck,as I'm following you,you have not stuck yours yet Flapper LOL LOL LOL fooled yerBlushing oops hope I haven't upset you.Blushing
#82 Posted : 12 December 2012 20:23:24
Its not the being stuck, but that your F27 appears to slope aft but must be the angle of your piccy [flapper]
#83 Posted : 28 December 2012 11:57:54
proceeded onwards,not using the bamboo,will use lime(basswood)instead.
#84 Posted : 29 December 2012 10:15:06
Looking good Karl...
#85 Posted : 03 January 2013 11:44:20
thank you alan. now this is how I'm going to plank the hull,at the moment using up my scrap 5x2mm.planking.awaiting 5x2mm basswood(lime)3 rows done will continue today to add more.
#86 Posted : 03 January 2013 12:00:28
each plank is individually tapered and BEVELED to achieve a tight fit to each other,the bend I used the crimp plank bender tool supplied for the victory,with the blade reversed to the blunt side.the bevel I used a mini plane similar to the one that tomick showed in his official build.the only reason I am not using the bamboo it that it was supplied with rounded edges,although it will be covered up with veneer,I just didn't fancy the overall finish,the sanding down will be easier for me too.it is simply my choice at a fair amount of extra expense. btw when using the crimper,if you crimp diagonally you will get the outward twist needed to compensate for the compound bend,meaning that the bow not only bends on a horizontal plane it curves downward too. that is what causes the clinker effect.
#87 Posted : 03 January 2013 14:51:34
Hi Karl,
Excellent example of this ship,thank you for posting.
Regards Trev.
#88 Posted : 03 January 2013 15:08:39
thank you for commenting.appreciated.
#89 Posted : 03 January 2013 15:14:39
that's the fifth row done.
#90 Posted : 04 January 2013 15:42:51
that's it for this week.
#91 Posted : 11 January 2013 13:44:59
having received my stock of limewood I decided to strip off old planking and start again,having soaked the old planking first,it came off all in one piece,(phew)replaced the transome planking first,now starting the main planking.
#92 Posted : 13 January 2013 11:00:14
nows the time to sort the lighting,tried various leds and ended up with 3mm.leds,x12v.with a 6v.x1200ma transformer to give the right depth of glow. what's the verdict folks???
these I hope will light the gunports so it looks like light is coming from the lower gun deck,the wiring is .03mm gold jewelers wire,which I got in 6mtr. reels @ £1.75 per reel,and that traversed completely around the gundeck twice so I could solder the leds,and then exiting out the stern to connect to a socket somewhere near by.hopefully I have placed the leds next to the dummy barrels without obscuring them.
#93 Posted : 13 January 2013 11:08:04
Nice work there Karl, looks very good.. My only concern would be whether the led's themselves would be visible when you cut out the gun ports especially as we do not yet know the exact position of these ports. In addition, you may find the led positions could restrict the positioning of the actual gun barrels. Just my thoughts, keep up the good work....Cool Cool
#94 Posted : 13 January 2013 11:15:33
hi al,I had thought long and hard about the positioning of the leds,that is why I put them in the corner,to leave the maximum area for the barrels,and if necessary they can be moved(the barrels that is)as the leds are only 3mm.that is not a lot space,so hopefully they will be ok(fingers crossed.
#95 Posted : 13 January 2013 15:26:26
Hi Karl,
Firstly love the build and the innovations.
As this is my first build on this scale i have decided against lighting, but in return for your help the other day about decking this might interest you or anyone else into lighting their models.
On the following site you can purchase a flicker unit, not one that makes all the lights flicker at the same rate but randomly via numerous outputs from the one unit.(several units available with different number of outputs).
Take a look at www.microminiatures.co.uk
Delboy271155
#96 Posted : 13 January 2013 16:38:51
thanks for that,but a little too expensive.
#97 Posted : 20 January 2013 15:42:15
decided to do duck boards from 2mm x 1mm and 1mm. x 1mm.
#98 Posted : 21 January 2013 11:43:02
Hans
#99 Posted : 21 January 2013 14:56:30
Some lovely work Karl. She's looking great. Love the lighting.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
IAN
#100 Posted : 21 January 2013 16:57:32
Hi Karl.....
The lime wood planking looks good.
Added lighting will look great.
Thanks for sharing.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
21 Pages «<34567>»
This page was generated in 0.206 seconds.
