36 Pages «<2122232425>»
#441 Posted : 12 December 2012 07:20:48
Hi Mike,
I`m not trying to apply pressure on you, but which Monday were you referring to in post #433? :)
#442 Posted : 12 December 2012 11:22:25
FITTING THE GALLERY ENHANCMENT
Hi Team, the painting is now finished. This session will cover the fixing together of the front ply and the rear ply in all cases ( rear Gallery and 2 side Galleries)and then to achieve the correct curvature on the three parts.
It is important during this process to take your time, "test and try" the parts as we go, this is not a race and we are not working to any time scale above all enjoy the build as I amBigGrin
POINT 1)
Prepare 8x lengths of 5 x 2 timber (this will be used to protect the paint work on the front ply parts ) cut them just short of the width of the side Galleries:-
#443 Posted : 12 December 2012 11:34:17
FITTING THE GALLERY ENHANCEMENT
POINT 2)
"IT IS ESSENTIAL YOU GLUE THE 2 HALVES OF THE PLY TOGETHER ON A FLAT SURFACE," (and not curved on the ship) this is to ensure the windows aline spot on.
POINT 3)
I have used PVA adhesive (wood Glue) and not Super glue, I find PVA works better for me.
Place a quantity of adhesive on some scrap wood and apply an even layer onto the part keeping the adhesive away from the windows.(I used a cotton bud for this purpose )
Then clamp the parts together as per the photos:-
#444 Posted : 12 December 2012 11:37:05
POINT 4)
and now do the same to the rear Gallery parts:-
#445 Posted : 12 December 2012 11:41:01
POINT 5)
Please leave the parts to cure for 24 hours (we want a secure fix) and when you remove the clamps your parts should look like this:-
#446 Posted : 12 December 2012 11:58:21
CURVING THE PARTS
POINT 6)
This is the most `tricky` part of the process, you really do need to be patiente all the way through TAKE YOUR TIME and "try and test"
I have never used plank benders ( some people get great results with these ) I prefer to use methods I have used from way back when, either steam, hot water or heat from a candle, and then a natural drying process, you will notice all the way through my builds I do not use any fancy tools.
POINT 7)
Take 2 plastic cups or beakers
Then using the spout of a boiling kettle run the side gallery part through the steam,painted side up( mind your fingers) you can use a pair of tweezers.
Do this between 6 to 10 times (duration each time the kettle boils) when the part is moist and plyable, place it between the 2 cups (one inside the other) in the position shown in the photo:-
#447 Posted : 12 December 2012 12:07:33
CURVING THE PARTS
POINT 8)
Ok Team leave the parts in the cups for two days to dry out thoroughly.
When you take them out they should look like this:- (PLEASE NOTE no cracking of the paint or splitting of the wood, if you use Admiralty paints you will be fine)
#448 Posted : 12 December 2012 12:16:37
CURVING THE REAR GALLERY
POINT 9)
We are almost through this session only the rear to curve.
This curvature is very small, we use part 79 from the DeaG VICTORY parts and fit it as instructed in the magazine instructions.
Fitting this part 79 gives the exact curve to the rear Gallery that enables it to fit the other parts already fitted to the rear of the ship, mark off with pencil where the part is being fitted and fix the part with adhesive:-
#449 Posted : 12 December 2012 12:22:43
POINT 10)
You will see by putting a staight edge across the inside rear of the gallery the curve you require:-
#450 Posted : 12 December 2012 12:25:57
Thats all for this session Team, questions and comments are welcomeBigGrin I will leave you with how the parts look at this stage Happy building
Kind regards Mike
jonny7england
#451 Posted : 12 December 2012 14:16:40
Gob-smacked Mike...Looks ruddy stunning mate...Drool ThumpUp
#452 Posted : 12 December 2012 23:26:59
Hi Jonny thank you for your comments much appreciatedBigGrin Kind regards Mike
#453 Posted : 13 December 2012 01:01:02
Hi mike.
Top class as per usual Ian.Cool BigGrin .
saintsman123
#454 Posted : 13 December 2012 16:34:05
have you used your felt tip pen technique for the gallery mike.
Come on you Jimmies
#455 Posted : 13 December 2012 17:26:00
Hi Bob,
not yet, I have used the Admiralty paints, but I will use the felt tip on the edgesBigGrin Thanks for looking in. How is your hand now?
Best wishes Mike
#456 Posted : 13 December 2012 18:28:08
ian smith wrote:
Hi mike.
Hi Ian thank you for your nice commentBigGrin Kind regards Mike
#457 Posted : 14 December 2012 21:17:45
Hi Mike!
That's a very impressive 'bending' procedure you've got there, so simple and like you said, no super-duper tools required for a perfect result!
I'll remember that one (if I ever get a ship with a wooden stern gallery)!
The DelPrado galleries would need a blow torch set on full to bend them into shape!BigGrin
Best Wishes
Robin
der Gohfelder
#458 Posted : 14 December 2012 21:24:09
Hi!
A very nice enhancement, explained really detailed! If I hadn´t finished my Victory...........BigGrin
Regards, Bernd
Jesus-Belzheim
#459 Posted : 16 December 2012 04:43:11
Hi Mike thank you for showing us how BigGrin
I hope I will get it done just as good as you ThumpUp
As soon as I`m ready with the copperplates
Till now i`m still doing the keel Blushing
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#460 Posted : 18 December 2012 02:45:44
Plymouth57 wrote:
Hi Mike!
Best Wishes
Robin
Hi Robin thanks for the nice commentBigGrin Kind regards Mike
Guest (17)
This page was generated in 0.304 seconds.
