Issue 6 Options
Allan
#1 Posted : 12 May 2010 22:20:18
ref: issue 6 the instruction 5 on page 12 it states
Carefully separate the remaining parts from the carrier sheet. Note that parts 17-22 (outlined in red) are not used
is it me or is there no No.17 ??????
Allan
Macmedal
#2 Posted : 12 May 2010 22:28:39
No 17 or 20 that I can see Confused
Allan
#3 Posted : 12 May 2010 22:33:58
Yes you are correct no No 20 either lol
Allan
snake
#4 Posted : 12 May 2010 23:48:12
No-8 lenght size seem smaller than no7 & no9 :/
#5 Posted : 13 May 2010 00:14:50
yes my findings the same as above but guess parts correct and instructions slightly wrong
snowtiger
#6 Posted : 13 May 2010 01:38:38
Nope No8 is not wrong ....it's just the holding collar is slightly shorter on one side and from what i have checked with the planks and a straight edge ....it's all good....it won't effect the build as that part is cut off and discarded next issue.....hope this helps....BigGrin BigGrin
John....BigGrin
tomo29
#7 Posted : 15 May 2010 22:21:32
your right there is no no 17 or 20 or 21 and in the mag but on page 12 it says to glue all the bits together but on gulde number 7 its says do not glue so how do this work out ?
snowtiger
#8 Posted : 16 May 2010 00:35:22
guys i think it will be explained in the next few issues.....we have the parts ....the numbers are right on the pieces but put down in the mag call it another typo....nobody is perfect..remember the cannon!!!....hope this helps
John...BigGrin
tomo29
#9 Posted : 16 May 2010 10:30:19
John...BigGrin
but if u look on the wood bits they are all numbered but there is not pice nos 17 20 only 1 to 18 and 19 then 22
Capt Stedders
#10 Posted : 16 May 2010 10:41:33
The rudder part seems quite different than the one in the mag (insofar as there appear to be recesses for hinges on the parts we are supplied with, whereas the one pictured in the mag is recess free).
Curiouser and curiouser..
Ho-hum.
Schnellboots on back burner
Tools.
Son of Bulwark
#11 Posted : 16 May 2010 11:09:49
Hi shipmates! BigGrin
Have you tried counting the parts of the laser cut ply sheet there is in fact 22 parts Two number 3 parts and Two 22 parts the laser cutter has done this and DeAGOSTINI haven't pick this up, just goes to show you can't delieve all you read. The picture show the same parts as we have so lets put this down to another mistake and see how it goes together! BigGrin BigGrin BigGrin
Some people can't count and others done check!. The question is in which country are the parts made in, think about it and you will probably get your answer. Not made in UK!.
Mike Turpin
#12 Posted : 16 May 2010 11:35:09
Ho-hum.
I think the problem probably arises from the fact that the magazine was based around a sample/prototype kit and not the final production version.
This is one of the problems of a part works that you can't just flick forwards a few pages in the manual to confirm these details. I assume there are some more parts to come to complete the launch and hopefully the tiller construction will become clearer.
Perhaps Tomick has more information that he could share on this one?
That's why I for one am not rushing ahead with the build, I would rather have a complete picture before committing too far ahead. Since receiving my issue 6 on Wednesday I am halfway through fitting each rib in the jig, allowing plenty of time for each rib to set at right angles before adding the next one.
Mike T
piot007
#13 Posted : 16 May 2010 14:29:53
yeah me too. im waiting at least 2mths. im a total noob here, and i'll let others find the pitfalls and mistakes before i start. cant believe im still waiting on iss 4,5,6. so i got no choice really.Bored im not in a rush to mess it up thoLOL
#14 Posted : 16 May 2010 16:12:37
No worries guys, the parts shown within the red box of issue 6 are set aside as per the info.
Then at issue 8, (from the box), the Keel is installed, (which is part #18 but has no number).
Then at issue 9, (from the box),the boomerang looking item is installed (bow brace), which is part #19 but has no number.
Which leaves the following parts from the box within issue 6 to place - part #21 Rudder, 2x part #22 corner brace, no info yet as to which issue these parts will be installed at.
For those querying the gluing of the two #3 parts in steps 6&7 of issue 3, you should not apply glue to the top of these parts, only at the bottom tab, when the jig is cut away at the end of issue 7, the two #3 parts should fall away with the jig.
Hope this helps Blink
This page was generated in 0.283 seconds.
