Clamping the launch planks Options
Bob Abell
#1 Posted : 10 December 2012 09:38:02
Having a real struggle, planking the launch!
Tried a new method of holding the planks in place, but still retaining fine adjustment!
Cut a plastic bag into 1/2" wide strips and use them to secure the planks. The secured planks can be prodded into position nicely through the clear plastic
Apply glue with a brush, to areas not covered by the plastic, initially, then gradually finish off in stages
Bob
#2 Posted : 10 December 2012 09:49:22
Why not use superglue?
Bob Abell
#3 Posted : 10 December 2012 09:52:39
The fumes from Superglue gives me a rash!
Bob
#4 Posted : 10 December 2012 09:58:23
Maybe try an organic vapour mask such as that from 3M
benny b
#5 Posted : 10 December 2012 20:21:31
hi bob if you have alergic reaction try mini clothes pegs there only very small and used in card makeing circles i tried them on mine and they seem to work ok i dont like super glue myself you can get them from ebay or most craft shops its just a thought for you
#6 Posted : 10 December 2012 20:48:30
Like I am some expert (not) but why not try the old fashioned way of pins.
I purchased some quite fine dress making pins from wilco. Cheap as anything and they work.
In most cases I believe these launches will be painted so pin holes should not be a problem.
Absolutly hate superglued and most things artificial.
The wilco pins are from that rack that sells the trouser turn up iron on tape; tape measures and various other "interesting " items.
Hope this might help but with so many other excellent hints and tips on this site sure you will find something that works for you.
Kind regards
This page was generated in 0.109 seconds.
