33 Pages «<1213141516>»
Surprise Build Log by Mo Options
saintsman123
#261 Posted : 04 December 2012 12:53:10
the caps look great mo.BigGrin
i used an electric drill and sandpaper for turning victories masts. i got an cheap oven glove and used double-sided carpet tape to hold the sandpaper. then wrap some masking tape round the bottom end of the mast and put it into the drill chuck, then you just fire up the drill and sand away, just be carefull that you don't grip the sandpaper onto the mast too tightly or you can break the mast.
a question for you, are those the supplied tops for the masts or did you make your own, as the walnut looks good.
Come on you Jimmies
Mo
#262 Posted : 04 December 2012 17:51:24
If your talking about the foretops for the masts, yes they were supplied with the kit. If you look at my post No 244 You can see the mast has had a coat of oak stain, and the foretops have not, But in the later posts you can see the foretops have also had a coat of oak stain, I am going to give all the walnut on the masts and yards a coat of oak stain, I really like the colour too.
Mo
Mo
Mo
#263 Posted : 04 December 2012 23:12:04
I have been doing the gun ports to the bow of the ship,
I then decided to go and give the anchor davit's a go. Quite a bit of geometry here, as you can see.
Quite a bit of work in this item, I still have to put the rosette on the end, and put the brass collar at the front and drill 3 elongated holes in the front for the pulleys, I am awaiting delivery of a vertical drill stand to do that. Anyhow plenty to do in the meantime.
Mo
Mo
yamaska
#264 Posted : 05 December 2012 01:16:37
Beautiful work on the catheads Mo. This is going to be a cracker.
John
Ger C
#265 Posted : 05 December 2012 02:07:44
Looks like she will be a model to be proud ofDrool
moriarty
#266 Posted : 05 December 2012 16:33:11
Been watching for a while now Mo and I reckon you are doing a first class job there. Nice piece of geometry on the catheads, well worked out. I have made up my mind bout coppering an I am going to have ago. I have laid down the waterline in wood to take the first line and am ready to start but need to build a jig to get the thing upside down, any ideas? Also can you give a measurement on the mainmast from the upper deck to the platform level cos it seems to be a height that does not look to be in scale but yours looks ok. Maybe it is just me but it is hard to scale things looking at build picturesCool
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
saintsman123
#267 Posted : 05 December 2012 16:41:23
Mo
they look good both stained and unstained.
cat heads looking good
Come on you Jimmies
Mo
#268 Posted : 05 December 2012 18:18:31
Moriarty,
I have a size on my drawing which goes like this. Main Mast, ( the middle one ) 65 mm from bottom of mast to top of the upper deck, 360 mm from the bottom of the mast ( again the very bottom of the mast, where it goes below the level of the lower deck ) to where the square section starts to accommodate the foretop. Giving you a size of 295 mm from top of upper deck, to underside of foretop. Hope this makes sense.
Mo
Mo
Mo
#269 Posted : 05 December 2012 18:25:53
Thanks all for your encouragement, I have really Surprised myself at the level of detail I have been able to turn out, So if anyone else thinks they might " not be able " it is amazing what you can do, if you put the hours and commitment into something. Don't want to say much more, I am a long way from finishing this project, the rigging I think will really test my witt's
Mo
Mo
moriarty
#270 Posted : 06 December 2012 01:53:49
Cheers Mo, it does make sense. I was about 55mm outfor some reason. must have got distracted and forgot all about it.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
hudsonrobert49
#271 Posted : 06 December 2012 07:19:27
Outstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Hi Mo, yes really good looking work you've got thereBigGrin BigGrin BigGrin
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Mo
#272 Posted : 09 December 2012 17:37:27
Still on the anchor davits, I have painted the rosettes, 3 coats, and painted the cleat things.
I have also bought a dremel drill jig, I needed this to bore the elongated holes in the timbers, I read a couple of bad reports about the jig, but all in all its fit for purpose, I would say.
The timbers are all painted and fitted now, I have also filled the holes around the cut outs to tidy them up and will paint, I am going to stick to the front of the ship now for a while, try to do the funny shaped bits.
Mo
Mo
petpole
#273 Posted : 09 December 2012 17:53:38
Looking great there Mo, the davits are nice bit of work and i like what you have done with rosets.
Keep up the good work.
BigGrin BigGrin BigGrin BigGrin BigGrin
der Gohfelder
#274 Posted : 09 December 2012 18:04:40
Nice progress, go on this way!
Regards, Bernd
Mo
#275 Posted : 13 December 2012 22:17:52
The Anchor davits are looking of now, filled and sanded and painted.
Mo
Mo
#276 Posted : 13 December 2012 22:29:01
The Anchor davits are all looking ok now, filled, sanded and painted.
I am sticking to the front of the boat for the next while, I am going to try and copy James Choi's build, the fancy detail around the bowsprit, His work is outstanding.
I have looked out all the pieces for this area, Studied the drawings and instructions, lol.
I am dry fitting first, just to make sure things look ok, and I will be painting before glueing in place.
This area around the bow is tricky, a lot of different colours of paint meeting here,Not going to drink to much this weekend, will need a steady hand for this task.
Mo
Mo
der Gohfelder
#277 Posted : 13 December 2012 22:33:33
Uups, a real challange and a lot of hard work to be done!
Regards, Bernd
Mo
#278 Posted : 13 December 2012 22:41:59
Yes indeed, Bernd, But we just have to take our time, and we will work it all out, I never really thought I could do such intricate work. Its coming up to the holiday period and should get quite a bit done over the next few weeks, I treat every small area as a project of it's own.
Mo 🚣 ⚓ 🍺
Mo
Mo
#279 Posted : 15 December 2012 21:24:41
Things seem to be taking an age just now, Can't see myself getting much done, anyway, I have had some remedial's to do, to the timber adjacent to the hole I bored for the bowsprit, As I was boring the hole some splinters came of and I have to cut out the broken bit and replace with a new bit. I have also fitted the timber painted red, to a position of about 5mm above the timber to the top side of the gun ports,
Thank goodness for the electric plank bender.
I have also bought a revolving cake stand, this is enabling me to turn the model around, just by spinning the cake stand. ( yet another great idea I found on this forum, )
I have also been completing the timbers to the centre line of the gunports, I had not done the front ones, as the bowsprit was not bored at the time of fitting.
There was also little pieces of timber to be fitted to the front, turning upwards, This again was very fiddly, and were had made and shaped to suit, I again have choosen to paint them Yellow Ochre.
Now comes the really really fiddly bit, These curved timbers to the bow, I am taking Moriaity's advice here and I am going to use Plastic, I have picked up some 2mm x 2mm pieces of plastic, So here goes.
The plastic is bending very well, and the superglue is sticking well also, Will report back later with more developments.
Mo 📐 ⚓
Mo
saintsman123
#280 Posted : 15 December 2012 22:06:56
looking good mo, i've seen the plastic used before, and it can really look good.
the one thing that i have noticed with this kit is the different woods. i wish the victory had come with walnut, sapele and other woods. it does not make much difference if you paint your models, but as i have said before my paint skills are terrible, so i like plain wood. i am not sure if the actual a/l victory kit comes with the various woods or not, but i certainly wish the partwork had been like the surprise.
keep up the good work, sometimes each area does seem like a kit in itself, but you are certainly doing a good job.
Come on you Jimmies
This page was generated in 0.201 seconds.
