help please Options
Nihalus
#1 Posted : 23 November 2012 20:08:40
Rank: Newbie
Hi guys
I'm very new to boat building and thought I would give it a try
Anyhow I've glued the ribs, keel and built the jig
Only I'm having a problem with the ribs they seem to be out of alignment
I've posted some pic showing all the ribs (not 5) put together on a spare piece
If more pics needed not a problem
Could you use your expert eye and take a look please
cheers guys Malcolm
Bob Abell
#2 Posted : 23 November 2012 20:21:32
Malcolm
Are you referring to the staggered shoulders on the ribs?
There are that shape because the hull is curved
Take a look at the official build forum and it will be more obvious
If I`ve misunderstood your question, please be more explicit
Bob
Nihalus
#3 Posted : 23 November 2012 20:27:21
Rank: Newbie
Hi thanks for getting back to me
Its more about the level for the decks most are level apart from ribs 21 22 and 26
Malcolm
Admiral Anti Spiral
#4 Posted : 23 November 2012 20:28:56
i noticed this myself, some of the ribs are placed at different levels its perfectly fine.
Processing - Progressing
Previous builds: HMS Victory
Bob Abell
#5 Posted : 23 November 2012 20:53:51
Hi Malcolm
The decks are curved too
The ribs are correct
Bob
#6 Posted : 23 November 2012 21:07:29
Hi Malcolm... don't think you have a problem here as the lower deck does rise slightly (about 2mm) towards the stern.....
Hope this helps you...
Nihalus
#7 Posted : 24 November 2012 15:02:36
Rank: Newbie
Thank you guys much appreciated
I was worried I'd have to start over
This page was generated in 0.115 seconds.
