Double sided masking tape Options
#1 Posted : 21 November 2012 20:59:11
Hi All
Does anyone know if there is such a thing as double sided masking tape as opposed to standard double sided tape?
At the moment I paint small items like gun port lids, drip boards etc on masking tape stuck down at each end, a double sided version would be so much easier!
Happy Building all.
#2 Posted : 21 November 2012 22:00:39
You could try thin double sided tape after rubbing your fingers across the surface to reduce the tac, or maybe a spot of blutac on the reverse of the part.
#3 Posted : 21 November 2012 23:03:30
As Tomick mentions.. Blutac always works wonders for me and a must for small parts etc
willie
#4 Posted : 22 November 2012 13:48:19
why not put the double side tape down then the masking tape on top of it that what i do
saintsman123
#5 Posted : 22 November 2012 16:02:31
great idea willie, ThumpUp ThumpUp ThumpUp i have always had problems getting things like rope coils off doublesided tape without destroying them.BigGrin
Come on you Jimmies
Ger C
#6 Posted : 22 November 2012 16:40:09
Great tipsBigGrin
#7 Posted : 23 November 2012 20:36:38
Thanks for the help and suggestions guys, double sided then masking tape! Now why didn't I think of that!!Blink
kwakermad
#8 Posted : 24 November 2012 19:25:24
Just wrap masking tape upside down round a couple of your fingers and voila double sided masking tape.
Bob
Builds in progress
1/12 Spitfire (Deagostini)
1/8 McLaren (Deagostini)
1/16 Stuka (Hatchete)
1/16 Zero (Deagostini)
#9 Posted : 24 November 2012 20:22:49
BigGrin I just cut a piece of masking tape, stick 1 end down flip it back fold over the other end stick it down,then press down on 1 end with your finger and strech it tight at the other endCool
