 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
I am interested in infilling the hull to make planking easier. However, I am unsure of the amount and size of balsa I need, the approx cost and the best place to buy from.
I know it's a big question, but can anyone help me out please? Also, are there any tools needed other than general modelling tools?
Lots of info amongst the Sovereign build diaries and in discussion
RobT wrote:I am interested in infilling the hull to make planking easier. However, I am unsure of the amount and size of balsa I need, the approx cost and the best place to buy from.
I know it's a big question, but can anyone help me out please? Also, are there any tools needed other than general modelling tools? Hi RobT. On my sos i used 2 off 1/2 inch by 36inch by 4inch wide lengths of balsa and i got them from http://www.cornwallmodelboats.co.uk/acatalog/
But there is also http://balsacabin.webs.com/index.html
http://www.alshobbies.com/ Toolwise knife, plane and sandpaper. A plane is not essentual but does help. Best regards. Mark
Joined: 17/09/2012 Posts: 12 Points: 26 Location: leicestershire
if you can find a local model plane shop they will stock different thickness balsa planks, may even off cuts you can buy.
Hi Rob...In my local modelling shop. they sell balsa wood in bundles of varying thicknesses which they order in from elsewhere? The bundles are only around two quid. I am sure that you would be able to pick something similar from a modelling or craft shop in your area?  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
