 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 09/11/2012 Posts: 69 Points: 177 Location: Manchester
I`ve just installed the lower deck, Issue 11, and it`s just crying out for the central joint to have some support underneath? Don`t like thin material, being glued....Edge to edge If you`ve forgotten to draw the pencil before glueing, it`s not a problem, just draw two outer lines from the side faces of the formers Can only guess they are for next weeks nails?  Bob
My diary mention's nails in 12, which are positioned along the centrelines drawn in 11
