40 Pages «<1718192021>»
Admiral Anti Spiral
#361 Posted : 16 November 2012 15:44:07
Great work mike keep it up :)
Processing - Progressing
Previous builds: HMS Victory
#362 Posted : 16 November 2012 18:45:47
Hi AAS thank you for the nice commentBigGrin Regards Mike
#363 Posted : 16 November 2012 20:00:53
Mike, the more I see of this enhancement the more impressed I become.... looking forward to seeing the finished product....
#364 Posted : 16 November 2012 21:03:17
Hi Alan, thank youBigGrin In Issue 12 we will be approaching a critical part of the build, when we fit the cannon supports it is very important that we make sure the spaces between the ribs are exact as we fit decks up the ribs of the ship.
I will be using a method that works for me, any differance between the measurement of the ribs at the deck level (by even 1mm) will throw the fixings out on the decks above.
Do not worry if your ribs above deck level have twisted a lttle ( I have 4 that have) they will straighten as we fit the Decks.
And do not be to worried about the stem it will move again (it is a living thing!)BigGrin Do not spend to much time on it at this stage.
Happy building Kind regards MikeLove
#365 Posted : 16 November 2012 23:21:47
Mike thanks for the heads up, you have now put fear into me with what lies ahead....LOL LOL..... Apprehensive to say the least and no doubt as we progress into the build we will find out just how accurate I have been..... Where indeed would us first timers be without the guidance of experienced builders like yourself..... Am loving it though.....BigGrin BigGrin
#366 Posted : 17 November 2012 10:25:59
MWG wrote:
ISSUE 11 BUILD
Thats all for this session TeamBigGrin Questions and comments welcome.
I will leave you with some photos of underneath the Hull and how I shaped and faired to rib 26:-
Kind Regards Mike
Cool Brill Brill Brilliant
I now understand how the fairing on the stern keel reinforcement plates
(part 24) works out.
I am in awe of your expertise and can only imagine how some of us newbies would be struggling without your master class.
Many Thanks
Delboy271155
#367 Posted : 18 November 2012 10:42:51
delboy271155 wrote:
MWG wrote:
ISSUE 11 BUILD
Kind Regards Mike
Many Thanks
Delboy271155
Hi Derek, Thanks for your kind commentsBigGrin I still have a little more to do, but at least you will get the jist.
Kind regards Mike
Ger C
#368 Posted : 18 November 2012 14:24:45
Hi Mike,
Great tips that can be applied to every ship, thanks again
#369 Posted : 19 November 2012 01:11:41
Ger C wrote:
Hi Mike,
Thank you Ger C,BigGrin Regards Mike
#370 Posted : 22 November 2012 14:30:02
ISSUE 12 BUILD
Hi Team well it is onward and upward.
I have incorperated a couple of enhancements this week, but first this is what we received:-
#371 Posted : 22 November 2012 14:43:10
ISSUE 12 BUILD
The object this week is to fit the Dummy cannon beams, and deck supports between the ribs, to support the next deck, wether it be another ply deck or deck planks, as yet we do not know.
I followed the instructions, no problems there, but I did add the two enhancements ---- the first was to also pin the beams to the inside of the rib with a pin punch, this gave a much better fix.
The second enhancement was the inclusion of a piece of 1/4inch dowel underneath the deck supports (Placed in the middle) the reason for this? well what ever deck we put on next we are going to apply pressure to the beams, this could result in breakages in the centre of the deck supports, its just an extra precaution:-
#372 Posted : 22 November 2012 14:47:31
ISSUE 12 BUILD
Please make sure the mast hole is free and in line by using a piece of dowel of the correct size:-
#373 Posted : 22 November 2012 14:54:00
ISSUE 12 BUILD
Well Team thats all for this weekBigGrin Thanks for looking in, questions and comments always welcomeCool
Please take your time while building, and please dont try to second guess what is comming next, be happy in the now, and you will have a great model
Happy building Best wishes Mike
PS I will leave you with a couple of photos how she looks now:-
#374 Posted : 22 November 2012 15:31:52
Hi Mike, nice idea with the bits of dowel. I take it there are no openings in the next deck to make them visible.
#375 Posted : 22 November 2012 15:48:22
Hi Greame,
MR T has alredy posted the next deck to be fitted will be the same ply as this one we have just fitted, plus there will be no deck openings, and so the dowel will not be seenBigGrin I hope that helps, kind regards Mike
#376 Posted : 22 November 2012 15:56:58
Hi, it just shows I need to keep up with the official build as well.
graeme
Jesus-Belzheim
#377 Posted : 22 November 2012 18:45:05
Hi Mike
That looks very good ThumpUp
Still waiting for the S.O.S to come out in Germany
And thanks for the answer about the glue BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#378 Posted : 22 November 2012 19:29:26
Hi mike.
Looking good.like the dowl idea.
Ian. Cool
#379 Posted : 22 November 2012 20:44:03
MWG wrote:
ISSUE 12 BUILD
Hi Mike
Not up to this point yet but I can see the wisdom in the dowel supports. I would not deem to teach an expert how to suck eggs, but my thought is that if we are fitting the same sort of deck as last time, then may be 3 dowel supports across each cross beam (evenly spaced) may give more pinning points ,or would that be classed as overkill.
Delboy271155
#380 Posted : 22 November 2012 22:19:55
Your usual high standards Mike, excellent work. I too intend to add additional supports for the next deck.. Would rather be safe than sorry....Cool
Guest (5)
This page was generated in 0.381 seconds.
