36 Pages «<1718192021>»
#361 Posted : 16 November 2012 09:11:43
Hi Walter, good question.
The lines on the stern Gallery are 2mm (top, middle bottem and sides)I will give other measurements as I go.
The side Galley measurements are 2mm (top middle and bottem)and 1.5mm on the sides.
Kind regards Mike
#362 Posted : 16 November 2012 10:51:16
Thanks Mike.
#363 Posted : 16 November 2012 12:28:25
Virtue86 wrote:
Mike
This is the first time i have looked at your victory build. Looking great as we have come to expect from your work. I have missed all the conversations about the Gallery enhancement but i am thinking of doing the same for my San Juan Nepomuceno when i get round to starting it. Due to the nature of my work i can do the CAD drawings for this and there are a few guys at my University that are willing to laser cut it for me, so all of your tips are a great help for the future.
Hi Peter sorry I missed your post thanks for looking inBigGrin Kind regards Mike
#364 Posted : 16 November 2012 12:31:26
Hi Peter ,Bernd and Ian for your commentsBigGrin Regards Mike
#365 Posted : 16 November 2012 14:22:08
FITTING THE GALLERY ENHANCEMENT
PAINTING
Hi Team how did you get on with the painting so far? 4 thin coats later when you remove the masking tape phase one should look like this:-
#366 Posted : 16 November 2012 14:26:34
PAINTING
Just to se how we are progressing I have placed ply 1 onto ply 2, BUT I HAVE NOTED GLUED IT YET!!BigGrin because we have more to do:-
#367 Posted : 16 November 2012 14:34:40
PAINTING
We must now mask the stern piece (ply 1) and the side gallery pieces (ply 1a and ply 1b) the object is to paint the black squares between the windows on ply 1 and extend the yellow ochre lines on ply 1a and 1b (we will mask and paint the black squares on ply 1a and 1b in the next session.
PLEASE DO NOT RUSH THIS PROCESS, YOU HAVE TO LOOK AT YOUR RESULT FOR A LONG TIME!!BigGrin Here are ply 1 and ply 2:-
You can see the black showing through on the ends all you are doing is following the 2mm thickness all the way through.
#368 Posted : 16 November 2012 14:39:50
PAINTING
Now we mask the Ply 1 first fit the tape down the way 1mm from the edge of the window sides:-
#369 Posted : 16 November 2012 14:45:01
PAINTING
When you have finished all the down tapes, you will then need to place masking tape across ply 1 covering the yellow ochre top and bottem of the windows, like so:-
IF YOU ARE NOT SURE WERE TO FIT THE TAPE PLEASE ASK!!BigGrin
#370 Posted : 16 November 2012 14:49:12
PAINTING
Having completed the masking as per the photos, please use the end of a paint brush and rub all the areas where the tape meets the parts so we make sure it is well fixed before painting:-
#371 Posted : 16 November 2012 14:52:13
PAINTING
Just for clarity these are the areas we are going to paint, with 3 to 4 coats of the relevant colour:-
#372 Posted : 16 November 2012 14:56:52
PAINTING
Thank you for watching, thats all for this session, please remember questions and comments are welcome.
You will realise while you are building this Enhancement you have something very special and uniqueBigGrin Kind regards Mike
PS I will leave you with a photo of where we are at the moment (one coat of paint completed.)
Riggers
#373 Posted : 17 November 2012 11:24:50
Hi Mike
The gallery enhancement is coming along nicely ThumpUp
Have to order a kit from you when I get to that stage of the Victory build.
Cheers
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
#374 Posted : 18 November 2012 10:37:23
Riggers wrote:
Hi Mike
Cheers
Hi Chris, thank you BigGrin no problemCool Regards Mike
daffy09
#375 Posted : 18 November 2012 20:16:31
Hi Mike
Just finished painting the window frames as per instructions. They look good,but the yellow ochre that I've used seems in my humble opinion, a tad dull when teamed up with the walnut stain, so I may well give them another coat of a slightly 'brighter' yellow ochre. I'll have to take a trip to the local art shop tomorrow and try again before I remove the masking tape. I have used an acrylic yellow ochre from Winsor & Newton's Galeria range which compared well with the colour patch I took with me for comparison and looked similar to the colour you tried originally for the small window panes.
Anyway,I'm sure it will turn out OK BigGrin
Thanks for all your help with this tutorial Mike,
and look forward to the next instalment.
David
mark 2
#376 Posted : 18 November 2012 21:48:31
Hi Mike.
I must say the gallery enhancement looks fantastic and when i get around to building HMS Victory i will use a few of your ideas if you dont mind.
Best regards.
#377 Posted : 19 November 2012 08:00:26
daffy09 wrote:
Hi Mike
David
Hi David not a problem, you use what you are comfortable withBigGrin Regards Mike
#378 Posted : 19 November 2012 08:02:45
mark 2 wrote:
Hi Mike.
Best regards.
Hi Mark, thank you, you can use as many ideas as you likeBigGrin Regards Mike
#379 Posted : 19 November 2012 20:59:16
PAINTING
Hi Team, here we are again with a further part of this rewarding buildBigGrin Lets have look at our results of last time:-
#380 Posted : 19 November 2012 21:07:41
PAINTING
The photos tell the story, you can see the new painted areas, from the black squares on ply 1, to the extra lines on ply 1a and 1b, I have again put the painted parts over the windows so you can see the effect I HAVE NOT USED ADHESVIVE, just dry fit:-
Guest (16)
This page was generated in 0.346 seconds.
