Drilling holes in the antenna of the Main Guns Options
dbartonjr
#1 Posted : 15 November 2012 19:47:43
Hello again, can anyone recommend what brand of drill and type/composition of drill bits for the 0.5mm and 1.0mm bits. I am not sure mine are strong enough to drill a hole as required by the instructions, steps 11 and 12 drilling into the command post.
Thanks for your help.
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 15 November 2012 19:57:24
An auto strike centre punch will help in centering the drill points and prevent the bit from skidding off. You'll also find that bits with a shank are much tougher than the norm.
This page was generated in 0.119 seconds.
