bitten by the bug.... Options
cptcrash
#1 Posted : 14 November 2012 17:16:31
ok ok...so i've been bitten buy the bug and gone and got myself the San Fran 2...
i'm slightly confused already by the instructions >< i know it didn't take long (i'm only on step two!! ) the instructions seem to say fit all the parts first and then glue them would it not be easier...or better to fit them/glue them indavidually one at a time to make it easier to check they are 90*?
pictures to follow...
ok so i've gone through and dry fitted the ribs but i'm now confused about rib 12 it doesn't seem to quite fit right...
pics should explain a bit better...
basicallly should i file the point on rib 12 down so it sits flush or should i just leave it as is? if i do that the top of the rib over hangs the false keel. is that correct or should that be level ><
curse my choice in hobbies....
This page was generated in 0.126 seconds.
