21 Pages <12345>»
Karl's Sovereign of the Seas Options
#41 Posted : 11 November 2012 23:43:57
thank you mike and alan,not fixed the prow or the stern ribs so more balsa filler later.
#42 Posted : 14 November 2012 11:44:36
this is how I've marked out the lower decks,I won't be nailing,instead I will be using screw clamps(see my build on the san filip)after first gluing
with aliphatic resin glue.
#43 Posted : 14 November 2012 12:43:19
If you have balsa'ed the hull be prepared to adjust the slots in the decks.
don't forget that the decks should be flush with the outside edge of the ribs.
claret
#44 Posted : 14 November 2012 13:20:23
Looking really good Karl.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Bob Abell
#45 Posted : 14 November 2012 13:25:45
Karl
Just curious......How come you are so far in front of the rest of us?
What issue number are you up to?
Bob
#46 Posted : 14 November 2012 14:11:28
hi bob this weeks issue from the newsagents is no.11.
#47 Posted : 14 November 2012 14:13:32
thank you claret for the nice comments.
#48 Posted : 14 November 2012 21:04:41
Very nice work Karl... almost at your stage and love how she is coming together... Keep supplying the pics and of course keep up the good work...
#49 Posted : 14 November 2012 21:26:48
cheers alan,have some more pics tomorrow.
mark 2
#50 Posted : 15 November 2012 07:29:35
Hi Karl.
You have done a very good job on sos BigGrin Cool.
Keep pics coming.
Best regards.
#51 Posted : 16 November 2012 11:06:31
thought the planking supplied a little too wide for the job so split it down the middle and made it 2mm.x.06mm.instead.looked more scale like.
#52 Posted : 16 November 2012 19:59:33
Very nice again Karl... certainly food for thought narrowing the strips down... Have started the launch for SOTS so will just continue but will certainly look at this when I come to build the Vic..... Keep it coming...BigGrin BigGrin
#53 Posted : 18 November 2012 13:05:42
that's the second skin put on,will now stain and varnish when the rest of the instructions are completed.the last pic is just a comparison with the other projects on the go,all are deag part works,sots,vic,vic x-section,san filip,and eaglemosses endeavour.
#54 Posted : 18 November 2012 13:12:07
Looks a mighty boatyard you have there Karl..
Ger C
#55 Posted : 18 November 2012 13:58:01
Very nice work Karl, keep the pics coming
#56 Posted : 18 November 2012 14:39:30
thank you tom,ger c,
#57 Posted : 21 November 2012 14:00:02
#58 Posted : 21 November 2012 23:11:09
sorry folks,forgot to explain what I have done so far.stained the decking,and made some beam supports,ready for the deck planking.here I 'm veering away from the mag,I will be making a deck from .06mm ply and covering with 4mmx 1mm, lime wood,and then staining in oak danish oil.but will hold off the decking until I see the mag.
#59 Posted : 21 November 2012 23:29:52
Very nice Karl, just wondering why you are staining the lower deck when it is to be fully enclosed and unseen...... only advantage I can see is you will know it is there...... loving your work though....BigGrin BigGrin
#60 Posted : 21 November 2012 23:31:16
Just so you know Karl, the next deck level is also plywood deck sections as per the lower deck rather than planked directly onto the beams.
21 Pages <12345>»
This page was generated in 0.222 seconds.
