1mm cannon balls? Options
#1 Posted : 12 November 2012 23:49:00
Hi Everyone!
Does anybody know of a supplier of 1mm cannon balls? (damn this 1/100 scale!)BigGrin
I've found a few suppliers of 2mm and upward but not the smaller ones I need.
Happy building to allCool
court orchard
#2 Posted : 13 November 2012 15:19:50
Why not make your own, 1mm Ball Bearings are readily available. Then you can Blacken them. I've just blackened the Cannon Balls supplied with the Victory X-Section successfully. The poorer the steel the better they will coat so buy the cheapest you can find and not Stainless.
court orchard
#3 Posted : 13 November 2012 15:39:07
Another Idea, you can also buy Silicon Nitride Ball Bearings which are black ceramic.
#4 Posted : 13 November 2012 17:59:56
Thanks for that CO
I was wondering if ball bearings went down to 1mm, I'll look into that as soon as I can. Its strange how some metals react to 'blackening' and others don't. I tried some of the brass chain that came with the Del Prado kit (for the rudder retaining chain) in some of my gun-blueing gel and it went a beautiful iron blue-grey which will be perfect, when I tried the brass wire that I've been making the gun tackle rings from it had no effect at all - rats!Mad I was hoping to avoid having to paint them all!!
Thanks again for that tip!
court orchard
#5 Posted : 13 November 2012 18:17:13
Hi again,
A lot of Brass and Copper is coated to stop it tarnishing or has grease residue from the manufacturing and this will block the process, I had the same problem with the Brass trunnion caps on the SOTS cannons, which were totally unaffected until I cleaned them in IPA.
This page was generated in 0.107 seconds.
