Planking Options
Bob Abell
#1 Posted : 12 November 2012 07:54:15
Hi chaps
I don't fancy all this balsa filling, but you chaps know best!
What are the dimensions of the planks please?
How many plank layers are there?
What week number does the planking start
Thanks a lot
Bob
#2 Posted : 12 November 2012 09:32:54
Bob Abell wrote:
Hi chaps
Thanks a lot
Bob
Bob, Mr T advised earlier that:
Indeed the model is double planked, the first layer being of 2 x 5mm bamboo which starts at issue 17, with the planking of the gallery and the first hull plank laid, and the second layer being a 1.5 x 5mm Sapele veneer plank.
As for the balsa infills, not something you have to do but I would advise at least doing the bow and stern sections. It will make fairing the hull and planking a lot easier.
Hope this helps.
#3 Posted : 12 November 2012 09:49:52
Balsa infill's are an aid to construction, they are not a necessity and the model can be constructed without infill's.
Hull planking starts at Issue 17.
There is indeed a second layer of hull plank which is sapele veneer, though at this stage it is unclear if the sapele is used just for the upper half of the hull rather than all of the hull, and that possibly a lighter wood will be used to veneer the lower half of the hull, (because of the lower half being white painted).
I will of course update as soon this this becomes clear.
Bob Abell
#4 Posted : 12 November 2012 10:54:03
Many thanks, Alan and MrT
Bob
Gaz
#5 Posted : 12 November 2012 19:09:37
Just a quick question if I may. How is easy does bamboo bend compared to say the planks we had with the victory
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#6 Posted : 12 November 2012 19:13:03
Have never worked with bamboo before so can't really answer you question as to how easy it is to bend... I have read it bends very well but is not the easiest wood to sand.... No doubt we will find out soon enough.....
This page was generated in 0.369 seconds.
