 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 09/11/2012 Posts: 69 Points: 177 Location: Manchester
Hello Chaps You may be interested in my set up? I`m using my old model aircraft fuselage assembly rig It uses multi adjustable angle brackets and seems to be ok  This is my first photo posting .....I hope it works! Bob
Joined: 01/09/2012 Posts: 111 Points: 306 Location: Nottinghamshire
Hi Bob,
Excellent idea, wish I could remember where I left my old one too.
Dave
A great idea Bob to resurrect this jig which is commonly used in model aircraft builds.
Its sold by SLEC, the brackets and self-adhesive grid layout are provided in a kit, all that needs to be provided is a base board and it be drilled.
Item "Building Jig Ref: SL054-S" in this link..http://www.slecuk.com/ca...ng-Aids.html#aSL057_2dR
Its certainly one to use for the 1/12 scale Spitfire build if and when it comes along
Thanks, Mr T
I bought the set from Woodvale, twenty years ago and never used it I knew it would come in handy, one day!
Bob
The only problem is that when you get to issue 11, (when you start to add the deck sections), you'll discover that this jig then becomes redundant, because the jig clamps are much taller than the keel, which means they you won't allow placement of the decks whilst the model is set in the jig, and won't be able to make use of the jig thereafter unless you cut down the bracket heights, which would ruin them for future use on model aircraft builds.
Thank you, Mr T
You are quite right there, Mr T.....I may cut them down later, as I don`t intend making any more airers anyway!
When the hull has a few planks and decks in place, it should be quite rigid and may take it out of the fixture and invent something else!
All part of the fun?
Bob
The good thing is that it brought something into play that has been laying idle, and indeed al part of the fun
There is indeed a 1/12 scale Spitfire in the system, but time will only tell if and when it might be rolled out here.
Here's a link to it..http://www.altaya.es/col...nstruye-tu-spitfire.html
Because they developed it and therefore get first bite of the cherry, in the same way that the SotS was developed in Italy and went on sale there first despite it being a UK ship and also the McLaren via Japan..
I wonder if deag have approached jotika? the agamemnon maybe,then we would be first. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
