MWG wrote:Thanks Alan, apart from the Balsa infill enhancement which has serious benifits to the build, I do like to keep things simple, hence I use lots of build techniques, which have been passed down from generations of modellers, so now you know I am not 21!!!!!!!! Kind Regards Mike No Mike, I now think you are 23.....
Neat idea Mike. Might use it, if I didn't enjoy messing about with chemicals so much  . Then again if the Wife found out what I was doing in her kitchen stuff I might have to stop too, luckily she goes out to work every day
ISSUE 9 BUILD Hi Team, continueing this section, you will see rib 26 has been fitted and the balsa has been filled between the ribs, please note not boxed as in the centre ribs but totally filled as in the Bow of the ship. I start by cutting the wedges from 1/2inch thick balsa (the decks have already been fitted this time with the 1/2 thick balsa):- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 9 BUILD Now a little trimming after the adhesive has hardened overnight:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 9 BUILD This is what she looks like at the moment, I only have to shape the stern, and the Hull will be finished:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 9 BUILD Thats it! for this session, all I have to do is assemble rib 27 with its relevant parts( leave you with the photos of that assembly) Questions and comments welcome  Thank you for looking in. Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Very nice indeed Mike, Alan
Gandale wrote:Very nice indeed Mike, Alan Hi Alan thank you for your nice comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Great job sofar Mike And thanks for your tips
Jesus-Belzheim wrote:Great job sofar Mike And thanks for your tips Hi Peter thank you for your nice comments. Also thank you for your payment for your enhancements  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Doing a fantastic job there Mike..Mine's on hold while I work on the Vic..Avidly following your build mate!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
jonny7england wrote:Doing a fantastic job there Mike..Mine's on hold while I work on the Vic..Avidly following your build mate!!  Cheers Jonny  Hows things with you,? not heard from you for a while, are you and the family well? Best wishes Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Fine now thanks Mike....Did my back in a short while ago...Just getting back into the swing of things, playing catch up on the postings...Keep the pictures coming Mike. great build mate...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Hi Mike, Great tips as always
Ger C wrote:Hi Mike,
Great tips as always Hi Ger thank you once again for the nice comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 9 (BALSA INFILL RIB 27) Hi Team I have now filled rib 27 with Balsa, I am really pleased with the result, I am going to show you lots of photos I am sure you will have no problem following the steps, I f you want more info pleases ask me. Here goes:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 9 (BALSA INFILL RIB 27) Well that is all for now, questions and comments welcome, we have now finished ISSUE 9, so upward and onward to ISSUE 10. I will leave you with how she looks now (please note the rib is not fixed with adhesive, just dry fitted)I have left the 2 slots with cutouts in them for I feel somthing is fitting in there (areas 34)if not I can fill them later. Happy building Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, Looking good with the in fill,not only dose it look the part but it makes it more ridged, also helps with the planking. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Very nice work again Mike. Think I am going to hold off on this part for a while, at least until I see what else attaches to the gallery... Will be infilling though when the time is right....
tf64 wrote:Hi Mike, Looking good with the in fill,not only dose it look the part but it makes it more ridged, also helps with the planking.
Kind Regards Trev. Thanks Trev, you are spot on with what you say  Kind Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
