40 Pages «<1415161718>»
#301 Posted : 01 November 2012 00:16:55
MWG wrote:
Thanks Alan, apart from the Balsa infill enhancement which has serious benifits to the build, I do like to keep things simple, hence I use lots of build techniques, which have been passed down from generations of modellers, so now you know I am not 21!!!!!!!!BigGrin
Kind Regards MikeCool
No Mike, I now think you are 23.....LOL LOL
court orchard
#302 Posted : 01 November 2012 00:17:09
Neat idea Mike. Might use it, if I didn't enjoy messing about with chemicals so muchLOL . Then again if the Wife found out what I was doing in her kitchen stuff I might have to stop too, luckily she goes out to work every dayLaugh
#303 Posted : 02 November 2012 11:06:21
ISSUE 9 BUILD
Hi Team, continueing this section, you will see rib 26 has been fitted and the balsa has been filled between the ribs, please note not boxed as in the centre ribs but totally filled as in the Bow of the ship.
I start by cutting the wedges from 1/2inch thick balsa (the decks have already been fitted this time with the 1/2 thick balsa):-
#304 Posted : 02 November 2012 11:11:10
ISSUE 9 BUILD
Now a little trimming after the adhesive has hardened overnight:-
#305 Posted : 02 November 2012 11:14:37
ISSUE 9 BUILD
This is what she looks like at the moment, I only have to shape the stern, and the Hull will be finished:-
#306 Posted : 02 November 2012 11:18:40
ISSUE 9 BUILD
Thats it! for this session, all I have to do is assemble rib 27 with its relevant parts( leave you with the photos of that assembly)
Questions and comments welcomeBigGrin Thank you for looking in.
Kind regards Mike
#307 Posted : 02 November 2012 20:55:49
Very nice indeed Mike, Cool
#308 Posted : 03 November 2012 04:24:46
Hi Alan thank you for your nice commentBigGrin Regards Mike
Jesus-Belzheim
#309 Posted : 03 November 2012 14:54:49
Great job sofar Mike ThumpUp
And thanks for your tips BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#310 Posted : 06 November 2012 00:29:56
Hi Peter thank you for your nice comments. Also thank you for your payment for your enhancementsBigGrin Kind regards Mike
jonny7england
#311 Posted : 06 November 2012 10:58:47
Doing a fantastic job there Mike..Mine's on hold while I work on the Vic..Avidly following your build mate!!
Wink ThumpUp
#312 Posted : 06 November 2012 11:29:01
Wink ThumpUp
Cheers JonnyBigGrin Hows things with you,? not heard from you for a while, are you and the family well?
Best wishes Mike
jonny7england
#313 Posted : 06 November 2012 15:00:06
Fine now thanks Mike....Did my back in a short while ago...Just getting back into the swing of things, playing catch up on the postings...Keep the pictures coming Mike. great build mate...
WinkThumpUp
Ger C
#314 Posted : 07 November 2012 00:43:12
Hi Mike,
Great tips as always
#315 Posted : 07 November 2012 17:04:33
Ger C wrote:
Hi Mike,
Hi Ger thank you once again for the nice commentsBigGrin Regards Mike
#316 Posted : 07 November 2012 18:20:45
ISSUE 9 (BALSA INFILL RIB 27)
Hi Team I have now filled rib 27 with Balsa, I am really pleased with the result, I am going to show you lots of photos I am sure you will have no problem following the steps, I f you want more info pleases ask me. Here goes:-
#317 Posted : 07 November 2012 18:33:17
Well that is all for now, questions and comments welcome, we have now finished ISSUE 9, so upward and onward to ISSUE 10.
I will leave you with how she looks now (please note the rib is not fixed with adhesive, just dry fitted)I have left the 2 slots with cutouts in them for I feel somthing is fitting in there (areas 34)if not I can fill them later.
Happy building Kind regards Mike
#318 Posted : 07 November 2012 20:51:29
Hi Mike,
Looking good with the in fill,not only dose it look the part but it makes it more ridged, also helps with the planking.
Kind Regards Trev.
#319 Posted : 07 November 2012 22:34:12
Very nice work again Mike. Think I am going to hold off on this part for a while, at least until I see what else attaches to the gallery... Will be infilling though when the time is right....
#320 Posted : 08 November 2012 01:04:22
tf64 wrote:
Hi Mike,
Kind Regards Trev.
Thanks Trev, you are spot on with what you sayBigGrin Kind Regards Mike
