Mast housing Options
Hector
#1 Posted : 22 October 2012 22:24:45
Rank: Amateur level 2
Hi guys/girls,
Don't think i've seen the topic covered so maybe only i have the problem,possibly filed a bit too much out cleaning up the pieces but my mast housing/keel piece 14 has free movement on all axis and i know a slight error here will be exagerated at the top of the mast so how do i make sure i get this right?
Thanks in advance
Rich
Tell me the truth,I shall not offend nor be offended
#2 Posted : 23 October 2012 00:12:22
repack the slot equally with card,when you are suer it's ok glue the card in the slot ensuring the mast holder is straight.
mabel7064
#3 Posted : 23 October 2012 00:20:30
Hello Hector,
I know that most people sand the burnt edges to clean them up but I find that a quick rub down with a dry cotton bud will remove the ash to secure a good fixing point for the glue without the need for sanding.
I came across a good tip awhile ago on the model ship world forum, which is to glue a piece of card on the area that has been over sanded using super glue (I used some from a cereal box) once the glue has dried soak it again with super glue. leave to dry and then sand it to suit.
I used this tip when I over did the fairing on the "Nina" build I've just finished and it worked a treat.
Hope this is of some use.
May xxx
mabel7064
#4 Posted : 23 October 2012 00:23:02
Sorry Karl,
I didn't see your post containing the same tip,
I think we must of crossed BigGrin
May xxx
This page was generated in 0.451 seconds.
