2 Pages <12
keel jigs /clamps Options
Hector
#21 Posted : 20 October 2012 21:47:23
Rank: Amateur level 2
ok i have my solution to the original post so this is more to do with figuring the pics
Tell me the truth,I shall not offend nor be offended
Hector
#22 Posted : 20 October 2012 21:50:48
Yes that certainly did help Andy:)) not the open picture but it does the job! Thanks mate
Rich
#23 Posted : 20 October 2012 21:58:40
BigGrin Hi Hector
NP m8 i had the same probs when i started with pics when you sort it its so simple its just getting there.
you now need to resize your pics on your pc using the 'edit' button in your pics folders, if you right click the picture you want then edit then you should see a resize tab, click on this then resize to around 600 by 400 pixels will load them direct to the page.Hope this helps
Hector
#24 Posted : 20 October 2012 22:01:56
Hector
#25 Posted : 20 October 2012 22:04:29
Try Again
Hector attached the following image(s):
Hector
#26 Posted : 20 October 2012 22:08:24
Hahaa simplesBigGrin thanks again,you can see the shadowing where the bow twists on this pic too.
Cheers Andy,thanks for your patience:)
Kind regards
Rich
#27 Posted : 20 October 2012 22:11:08
BigGrin Not at all m8 its what the forums for to help each other outCool
#28 Posted : 20 October 2012 22:25:12
BigGrin Hi Hector
you could try glueing two small wooden blocks[4 in all 2 each side]where the 2 tabs on the front keel support go into the keel,this then should hold it straight untill the major components are added or its a strip down and soak then put under a weight to remove the warp.hope this is of help
2 Pages <12
This page was generated in 0.115 seconds.
