cannon blocks Options
dave007
#1 Posted : 18 October 2012 20:47:42
Hi can any one tell me what stain/varnish to use on the cannon blocksBigGrin
court orchard
#2 Posted : 18 October 2012 21:10:26
Hi Dave,
I wouldn't Varnish them, too much risk of blocking up the holes, which is not good. I stained some of mine, by soaking them overnight in Dark Oak or similar, Rustins or Colron are OK. These are more of a dye. Don't use the thicker varnish types for the reasons above. However, it's about personal preference, I like darker blocks, but you can just leave them as is.
dave007
#3 Posted : 18 October 2012 22:40:18
Thanks for the advice and tips will go for the darker blocks like yourselfBigGrin
extinctionjet
#4 Posted : 18 October 2012 23:26:13
Hey dave, i had a similar issue, i didnt want any shiny wood so i went for a wood stain, goto HOMEBASE for £7.89 you can get a little pot of:
Ronseal Quick Drying WOODSTAIN - DARK OAK.
Im happy with the results, looks like they are genuinely solid hard wood that take alot of abuse from the canon itself.
catman275
#5 Posted : 18 October 2012 23:52:43
if you are going to leave an item to soak in wood dye/stain make sure it is in a glass or metal container.
I left some gun carriages to soak overnight in a plastic container (not my usual one) and in the morning it had melted!
I had plastic coated carriages. Fortunately it was in my shed and I ended up with was a nicely stained workbench.
cheers all Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
This page was generated in 0.145 seconds.
