Hi Rob. Comming along nicely, keep up the good work. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 20/12/2011 Posts: 236 Points: 686 Location: shetland
Thanks Ian , I am getting there
Hi all again, two photos of the ronseal filler before sanding, nearly covered it all  this stuff dries quickish. more sanding tomorrow. Some pieces have fell off,me being clumsy, easy put back on though. cheers rob sandnesspeats attached the following image(s):
Hi all, The hull is now even but dull in parts but I will finish off now with very fine sandpaper then on to the next stage. When exactly do you paint it?? cheers for now. rob sandnesspeats attached the following image(s):
You are lucky, you have some place outside to do the sanding. I have to sit in my little room with a surgeons mask in my face :) Greetings, Walter Greetings, Walter
hi Walter, about as much room as they had on the Victory eh!!  . Greenhouse is handy after the plants have finished. cheers rob
Hi folks!! I think I have finished sanding,the white blemishes is filler but very slight, the brown ones is the glue and sawdust(mixed) Does anybody think that a dark varnish would hide the filler?? or would you recommend painting it. Any thoughts would be gratefully received as usual. cheers rob ps Hope you can see it ok sandnesspeats attached the following image(s):
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Why dont you copper it. If you got that smooth it will be a doddle and it wont half look the buis  .iness HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
I am just not sure about the copper finish,I suppose it would hide all the miscolours,see when i come to it cheers rob
Its not there to hide anything, it is a fantastic finish in its own right.
Stain is an option perhaps but copper paint, never.
John
How much are these tiles anyway,have heard a lot about them.
Have a look at cornwallmodels site. That will give you an idea and on that scale you might be looking at 1000 at least but I dont know HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Joined: 02/09/2012 Posts: 81 Points: 252 Location: Kingston upon Hull
Hi Rob, £59.99 from the DeAgostini web site with free P&P. Sounds alot but you get approx 4500 tiles so it's 0.013p per tile. Just got mine deliveried this week small package but the tiles look good quality. Take a look here on my build dairy bottom of the page. Hope that helps  . Cheers Chris Builds in progress: DeAgostini HMS VictoryDeAgostini McLaren MP4-23 " If it looks right then it is right "
moriarty wrote:Have a look at cornwallmodels site. That will give you an idea and on that scale you might be looking at 1000 at least but I dont know Hi Moriarty, CMB do not have any copper tile in 1/84 Scale, the ones from DeAg are the only tile at the correct scale Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi all thanks for all the info greatly appreciated  . They do seem expensive but xmas is looming so you never know. It looks like a lot of work eh!! see what happens when i come to it. cheers rob
hi all, sorry for being a pest Has anybody had this problem trying to fit this bow stem and there is a gap in the middle,do I just keep taking it down until it is flush??. thanks again. rob sandnesspeats attached the following image(s):
What a difference some sanding can make, its coming alon nicely. Steve..
farrabass wrote:What a difference some sanding can make, its coming alon nicely. Steve.. Thanks Steve It just transforms it  , I had my doubts before sanding I have to admit.
sandnesspeats wrote:hi all, sorry for being a pest Has anybody had this problem trying to fit this bow stem and there is a gap in the middle,do I just keep taking it down until it is flush??. thanks again. rob That's what I did. Try the keel at the same time as well. John
Guest (6)
