Hull Guides J & K Options
dbartonjr
#1 Posted : 18 October 2012 13:35:17
I have looked at the documentation for the hull guides and it appears that they are missing templates for J & K. Where they sent in the dispatch, in which case they did not. Can anyone tell me where I can get them. Finally I assume that I will have to print them as is since they are in 8.5 x 11 format rather than A4. Is this correct?
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 18 October 2012 15:15:09
For Yamato parts replacement queries, email: customercare@deagostini.co.uk or call 0845 1489 250
#3 Posted : 18 October 2012 19:56:09
BigGrin Hi DJ
the down load is missing the two templates you mention, but all the templates are sent later printed on cardbourd[ i think about 4 issues/months later on in the build].I didnt use them myself as i shaped the hull by eye in this area using the stern block as the master shaper,there shouldnt be a problem in this area if you use your experience i/e if it looks right it is.hope this helps
