22 Pages «<202122
Stefan's build Options
Jesus-Belzheim
#421 Posted : 09 October 2012 19:03:41
Looking just great Stefan Love
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
StefanDV
#422 Posted : 10 October 2012 09:22:10
Thanks Peter.
I managed to fit 8 tiles to the bottom part of the keel last night.
At first I filed them to size, but this proved most tedious and not very accurate - even holding the tiles in a little jig didn't help. I ended up cutting little strip off the side with scissors and then trimming it with the knife.
Now that I have the 'hang' of it, it should go a little faster.
Hans
#423 Posted : 10 October 2012 10:34:35
Good looking job there Stephan. Can imagine it must have been very tedious and pushing your patience to the limit. As the saying goes "where there is a will there is a way".
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#424 Posted : 10 October 2012 13:11:24
Tiles look Good I have nearly compleated tiles (thankfully) and I have found scissors the easiest way of cutting tiles to size.
J
#425 Posted : 10 October 2012 14:04:05
Hi Stefan, you are making a great job of the tilesBigGrin good stuff Regards Mike
jonny7england
#426 Posted : 10 October 2012 18:39:32
Looking great Stefan!! Glad I didn't go down the tiled route though, otherwise I couldn't have taken on the SOTS build..Keep the pictures coming mate...
Love ThumpUp
StefanDV
#427 Posted : 15 October 2012 09:10:09
Thanks Gentlemen!
Finally the tiling of the hull is complete.
View from the stern:
View from the Bow
Started on the Rudder:
I'll do a once-off clean of all the tiles once the rudder is complete.
saintsman123
#428 Posted : 15 October 2012 13:21:45
looks good stefan BigGrin
Come on you Jimmies
StefanDV
#429 Posted : 16 October 2012 09:32:42
#430 Posted : 16 October 2012 09:59:02
Looks great!
I hope you find a way to clean the "discoloured" parts.
I plan to tile my hull as well, so am very interested, if there is a solution for this problem.
#431 Posted : 16 October 2012 15:45:43
Hi Steffan.
excellent job. looks realy impressive. Look forward to seeing some more pictures of your build Ian. Cool
Riggers
#432 Posted : 16 October 2012 22:29:24
Hi Stefan, like the look of your copper tiled hull ThumpUp just received the tile pack myself be a while before I can use them though need to build the hull and plank it first! looking forward to the experience. Hope I can get it looking as good as yours BigGrin
Cheers
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
StefanDV
#433 Posted : 18 October 2012 04:48:53
Thanks so much Walter, Ian and Chris for your most gracious comments! Blushing
A bit of progress on the rudder:
View from the front (side that will face the hull). You can see the areas that needs to be touched up where a file was used to get the tiles flush with the 'pintle' gaps.
Bottom view:
farrabass
#434 Posted : 19 October 2012 13:02:24
Congratulations on finishing the tiles.
Steve..
Jesus-Belzheim
#435 Posted : 20 October 2012 16:43:07
Hi Steve
You did a great job there, the copper plating looks marvelous ThumpUp
Kind regards
Peter BigGrin
22 Pages «<202122
