25 Pages 123>»
Claret's SOTS Build Diary Options
claret
#1 Posted : 04 October 2012 13:34:40
Hi,
Thought I would join the build diary, and hopefully pointed in the right direction if I struggle with any aspects!
I have done some painting and assembly, mainly the first two cannons, blocks and rib formers, and would have included pictures, but seriously struggling to do so. Photo bucket account opened, URL thingy pasted to now avail!
I will try again later, as it is obviously possible, due to all the great pictures already posted.
Claret.
Tried one last time before posting, preview shows a pic, but flashes off. Fingers crossed!!
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Dontshootme
#2 Posted : 04 October 2012 14:05:07
Looks good.Try resizing your pics to 600x450,they will show up then without a link,it's easy to do on photobucket.
claret
#3 Posted : 05 October 2012 09:01:49
Hi,
The other cannon, painted and ready for the blocks.
Been a busy week, so hopefully I can get some more model building done this week.
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#4 Posted : 05 October 2012 09:03:13
Thanks Rob, I think I have cracked it!!
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
Dontshootme
#5 Posted : 05 October 2012 09:15:53
You have definitely cracked it,but they could do with being a bit smaller,try 600x450,thyats the size I use as do most other people...that or somewhere in that ballpark.
Gus W
#6 Posted : 05 October 2012 10:12:17
Nice looking cannon Claret. Cool
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
claret
#7 Posted : 05 October 2012 11:08:15
Hi Guys,
Thanks for your comments.
I will have a go at getting the size right!
Hopefully I will get it sorted before the the model is completedLOL
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#8 Posted : 05 October 2012 11:52:04
Hopefully this will be the right size, not sure where you make it 600x400. Cropping constraints have a 4x6 but I think that is for printing.
Please be patientBlushing
[img][/img]
Also working on:
SOTS.
finished:
007 Iconic DB5.
Ger C
#9 Posted : 05 October 2012 14:13:34
Your cannons look very good.
Dontshootme
#10 Posted : 05 October 2012 17:29:15
click on pic you want to resize,at bottom left in blue border Switch to Advanced Editor,click on image tab at top,select image size,then resize to whatever you want..dont forget to save!
Photobucket now has a limited edition of photoshop from the looks of it so there is a whole lot more you can do if you are adventurous!
claret
#11 Posted : 07 October 2012 17:29:36
Hi,
i have made the blocks for the cannon, took a while to master, than the technique clicked. very fiddly though, and i assume this will be the norm?
I purchased 1mm eyelets from Caldercraft to replace the eyelets supplied with the model, built a jig and sprayed all 100 at one, after opening them up slightly to thread the wire loop on the block on. I then closed the gap with a drop of super glue and painted it matt black.
Also a pic of the anchor. I have not stained the wood yet, will wait and see what the model instructions suggest.
A busy weekend, taking advantage of a rainless day to assemble the jig. will finish when I receive issue 7.
a few problems with warping, but now have the wood pieces stored under weights.
Claret
[/URL][/img]
[/URL]
[/URL]
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#12 Posted : 07 October 2012 17:43:45
hi,
Still not getting photo's right.
tried resizing, but still looking small.
Also working on:
SOTS.
finished:
007 Iconic DB5.
Dontshootme
#13 Posted : 07 October 2012 19:38:13
Not sure what youy did with the 3 pics..except maybe choose thumbnail option,but the pic above is perfect.
claret
#14 Posted : 08 October 2012 00:03:39
Thanks Rob, not sure myself, will keep trying.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#15 Posted : 08 October 2012 00:18:43
Claret
Claret, using any picture editing software resize your pictures to 600 by 400 pixels and make sure 'Keep aspect ratio' is unticked.... then simply attach, post, browse to your pic, upload and post again,,,,, job done..... Hope this helps....
You can also hover the pointer over your pic and right click, select edit then carry on the above..... just another tip.. You don't need to use Photobucket or anything else for that matter....
Mo
#16 Posted : 08 October 2012 08:19:35
Your picture in post 12 is ideal, I had a lot of trouble at the start trying to get the pictures up too, but you soon work it out, and it's well worth the effort. You work is looking really clean.
Mo
Mo
claret
#17 Posted : 09 October 2012 14:22:17
Thanks Mo.
I will get there.
100 painted 1mm eyelets.
My jig, waiting for issue to complete.
Hope you like.
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#18 Posted : 14 October 2012 21:55:13
Hi,
I have opted for the mods Mike has recommended and done with balsa wood. As this is my first wooded ship, anything that makes things easier long term can not be bad. The thought of the planking does seem dauntingOhMyGod
This is my attempt of the bow.
I hope you like.
Also working on:
SOTS.
finished:
007 Iconic DB5.
court orchard
#19 Posted : 15 October 2012 00:13:20
Nice work on the Bow. Planking is only daunting in that it takes a lot of time to do properly.
mark 2
#20 Posted : 15 October 2012 07:19:04
Hi Claret.
You have made a great start with the Balsa work BigGrin Cool .
Keep pics coming.
Best regards.
Guest (8)
25 Pages 123>»
This page was generated in 0.203 seconds.
