Joined: 30/03/2011 Posts: 12 Points: 36 Location: Stratford upon Avon
Hi Guys Been following this forum for some time and have only just started my build, done front wing/nose and other bits up to issue 9 all a bit tricky as I m no experienced modeller, however came to issue 10 and have a real problem getting screws to bite, in fact this has been a real problem so far. I've taken on board the lubrication suggestions and tried that but the simple fact is the screwdriver doesn't give any purchase, in fact it's as if it's the wrong driver for the job I purchased a Wera (I think that's right 00 Phillips off Ebay) and really that is no better Has anyone had the same issues or does anyone have a solution, I have no problem gluing the parts but when it comes to the screws I dread the thought Any help would be appreciated Thanks in advance Andy
Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
I bought a set of cheap modelers screw driver set from a cheap shop containing size 00 - 0 - 1 and found this a bit better to hold
Joined: 19/04/2011 Posts: 17 Points: 41 Location: Wales
I've found that there seems to be quite a variation in the quality and size of the screw heads and currently use a number of different screwdrivers depeding on the fit. As a further tip, I have also kept one spare of each screw size/type into which my WERA screwdriver has a good fit and I use these spares to cut a thread for me before fitting the actual screws - found this to work quite well and stops me damaging screw heads when trying to get one of the poorer screws into place. I currently use: - WERA Phillips 00 Stanley Phillips 00 Screwdriver provided with the kit Phillips 00 from a cheap jewellers kit.
Supposedly these are all 00 heads, but no two are alike. Keeping my "thread cutting" screws to hand, I'm not having problems like I did at the start.
