24 Pages «<1415161718>»
My build another sequel Options
#301 Posted : 06 October 2012 11:32:42
BigGrin Hi Denissimo
using tin to cut down on weight is a good idea as for the milling out i hope your going to use a lathe or simular as the castings are of a very hard metal[i sometimes think there titanium based there so hard to file back].I hope your going to do a diary of your build ,i for one will be most intrested
saintsman123
#302 Posted : 06 October 2012 11:46:26
great work on the bridge andy, as you say it looks the part now.
Come on you Jimmies
#303 Posted : 06 October 2012 12:04:39
BigGrin Hi Saintsman
thanks for the kind words
Yutaro HONMA
#304 Posted : 06 October 2012 16:35:20
Hi shipmates!BigGrin
About the weight of the bridge block of this model, I think it surely too heavy. DeAGOTINI Japan buys the original models from WoodyJoe that is a wood model company in Japan. It sells almost same model in Japan shown as following URL.
http://www.woodyjoe.com/catalog/250yamato.html
One of the difference between WoodyJoe model and DeAGOSTINI's one is that bridge block of WoodyJoe model is made of wood parts.
Confused I don't know the reason why DeAGOSTINI's model uses metal parts, but the metal parts make the weight be increased in.
The problem caused by excess weight influences not only RC but also display stand.
The stand that is provided by DeAGOSTINI supports the hull by its 4 props. Such structure shall make the heavy model be damaged.Crying I have put the model on the panel that is put on the 4 props of the stabnnd.
Best Regards,
Yutaro
#305 Posted : 06 October 2012 17:25:33
BigGrin Hi Yaturo
thanks again for providing some excelent information
#306 Posted : 06 October 2012 17:31:04
BigGrin Hi All
i have spent today scratch building the upper bridge island gun stop rails,i was wondering what to do with that wire provided for the deguasing lines and now its came in usefullLOL .As ussual all comments and questions are welcome
#307 Posted : 07 October 2012 00:02:50
Hi Andy,
Had a look at your post today,that look's very skillfully done Andy I do no what it takes to bend and bow small gauge wire,a day well spent Andy.
Well done, great build.
Regards Trev.
#308 Posted : 07 October 2012 00:44:23
BigGrin Hi Trev
thanks very much for your comments
Ger C
#309 Posted : 07 October 2012 01:10:37
Hi Andy ,
Another piece of great workmanship, this may seem like a silly question but do you paint and prime these smaller additions by hand or by airbrush?
Thanks
#310 Posted : 07 October 2012 09:05:25
BigGrin Hi Ger C
thanks for your kind words,as for the painting question i generaly brush coat these at 1st but i will be going over it with an airbrush later in the build to even the colour tones up in the grey
Ger C
#311 Posted : 07 October 2012 10:42:47
Thanks Andy for the quick reply
Stupot
#312 Posted : 07 October 2012 11:53:28
Hi Andy, I'm not building this model but just spent the last hour looking through your build diary.Wow.What an amazing build.I normally build smaller plastic models & i didn't realize the amount of work that goes into building a large wooden ship.It looks great & will be a real work of model building art when finished.Stuart.ThumpUp
#313 Posted : 07 October 2012 12:18:17
BigGrin Hi Stupot
thanks for looking at my diary and your kind words much apreciated,as for the detailing i just felt that a model this size more than waranted the extra add ons i have obtained.Its just my way of showing others that its possible to improve a model either by scratch building parts or aftermarket suplyers,glad you enjoyed my diary so far theres still loads to come[ 5 issues left on my sub]
Yutaro HONMA
#314 Posted : 09 October 2012 15:46:26
Hi Andy!
Your scratch building of gun stops looks real. If you are searching for more information about them, I recommend you to refer to the URL below.
http://www.geocities.jp/...museum/yamatomuseum.htm
This page is written by Japanese DeAGOSTINI's Yamato model builders' club . Off course, I am one of the members of it. You can see a lot of photos of 1/10 Yamato model in Yamato museum in Kure city.
Click "その他の砲塔" and you can see the bridge island's guns photos. I hope they would help you make the model.
Best Regards,
Yutaro
#315 Posted : 09 October 2012 17:30:27
BigGrin Hi Yaturo
I have been using J Skulski,s book of drawings for the Yamato compared to the 1/10 scale there is a slight discrepancy at the 2 bridge anti aircraft guns but the rest are the same.Thanks for looking in
#316 Posted : 13 October 2012 17:33:37
BigGrin Hi All
More hull bits this month,i only added the stern scuttles to the starboard side as there never was a port side one in this area.I still have some enhancments to add around the bow area but more on that after i do them.So all thats left this month is a bit of painting and the adding of the 18 inch gun barbetts,i have some enhancments planed on these too ,more pics to follow.As always all comments/questions are welcome
saintsman123
#317 Posted : 13 October 2012 17:52:00
looking good andy.BigGrin
Come on you Jimmies
#318 Posted : 13 October 2012 19:01:06
BigGrin Thanks for looking in Saintsman and thanks for the comment
#319 Posted : 14 October 2012 13:05:21
BigGrin Hi all
Added some more etch to the bow area,a few hatches,anchor brake wheels and various brackets.I have also painted up the crysanthemum crest in gold.As always all comments and questions are welcom
Ger C
#320 Posted : 14 October 2012 13:36:57
Looking good Andy
This page was generated in 0.308 seconds.
