9 Pages «<45678>»
MWG build diary of the HMS Victory X - Section Options
Jesus-Belzheim
#101 Posted : 04 October 2012 17:52:29
Great job there Mike,
The Walnut looks very good ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#102 Posted : 04 October 2012 19:14:37
Hi Peter I am glad you like it. the grain looks just like oak, thank you for the commentBigGrin Regards Mike
court orchard
#103 Posted : 04 October 2012 19:25:48
I've subscribed to the X-Section and one day it may even arrive. When it does I'll be following your build with a keen eye. Love the work with the Walnut (0.5mm??). Gets rid of all those ugly plywood edges. Keep up the excellent posts and work.
#104 Posted : 04 October 2012 22:45:46
Hello Mike,
Had a look at your last post,your X section is looking very good I can tell by your craftmanship you are enjoying this build, such a good idea
to cover the riders and mast step.I will be working on my x-section this weekend so I will be posting a few more pictures.
Kind Regards Trev.
#105 Posted : 05 October 2012 02:00:56
tf64 wrote:
Hello Mike,
Kind Regards Trev.
Hi Trev, Thank you so much for your nice commentsBigGrin , You are right so far I am loving it. Kind regards Mike
#106 Posted : 05 October 2012 02:04:38
Hi Andy, I look forward to welcoming you to the buildBigGrin the Walnut is actualy 1mm sorry for the wrong infoBlushing Kind regards Mike
#107 Posted : 09 October 2012 12:58:08
ISSUES 129 AND 130 BUILDS
Hi Team, well here we are again as you know I am planking the main beams, the pump well and the mast base to cover the ends of the ply wood.
I have also modified the deck limbers, I am using the Anatomy of the ship for my information.
All the build in the photos is dry fitted, I do not intend to use adhesive untill I am satisfied that all is well.The insructions in Issue 130 tell you to stick the pump well in place, this to me is a no no because it is difficult to plank the pump well when it is fixed in the confined space, better to plank it outside the hull.
Here are photos of the beam being planked:-
#108 Posted : 09 October 2012 13:06:27
At this point I stained the sides of the beams with Georgian Medium Oak (Coloron Wood Dye) and thinned it with white spirit to obtain the same colour as the walnut planking I am applying. -- PLEASE NOTE I applied the dye before I planked the beams so that it would not "bleed" onto the planking:-
#109 Posted : 09 October 2012 13:08:08
Then I planked the ends of the beams:-
#110 Posted : 09 October 2012 13:11:05
ISSUES 129 AND 128 BUILDS
I gave the mast base the same treatment, applying the dye to the sides before planking:-
#111 Posted : 09 October 2012 13:15:33
Now it is the turn of the pump well to be planked again I am using my 5mm x 1mm walnut planking:-
#112 Posted : 09 October 2012 13:18:44
This is what we received in issue 129:-
#113 Posted : 09 October 2012 13:22:33
ISSUES 129 AND 130
I decided to plank the stand with my walnut planking, during this process I soaked the planks to form them around the curves, clamping them while wet untill dry but not using adhesive:-
#114 Posted : 09 October 2012 13:30:48
ISSUES 129 And 130 BUILDS
Well Team thats the end of this session, the modifications I am doing are my preffered build, you do not have to follow me.The pump well has been dyed with the mix I prepared earlier.
Questions and comments are welcomeBigGrin
I will leave you with photos of where I am upto at the moment.
No part has been fixed with adhesive yet.
Kind regards
Mike
#115 Posted : 09 October 2012 14:17:22
Hi Mike,
Great work very creative good presentation Mike again your work is outstanding thanks for posting to us all.
Kind Regards Trev.
#116 Posted : 09 October 2012 17:12:49
BigGrin Nicely done as ussual MikeCool
Jesus-Belzheim
#117 Posted : 09 October 2012 19:27:20
Well done Mike, It looks very good ThumpUp
Kind regards
Peter BigGrin
Hans
#118 Posted : 10 October 2012 10:48:09
Brilliant stuff there Mike. Nice and clean as usual. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#119 Posted : 10 October 2012 12:51:05
tf64 wrote:
Hi Mike,
Kind Regards Trev.
HI Trev thank very much fo the nice commentsBigGrin Regards Mike
#120 Posted : 10 October 2012 12:52:12
Thank you AndyBigGrin Regards Mike
9 Pages «<45678>»
This page was generated in 0.373 seconds.
