Is primer necessary? Options
samtt600
#1 Posted : 03 October 2012 15:11:15
Rank: Newbie
Hi, is primer absolutely necessary for a good finish as im struggling to find a shop local to me that sells it as im not one for shopping on the internet. I'm using acrylic paints if that makes any difference to the answer.
Thanks in advance
Sam
#2 Posted : 03 October 2012 15:45:46
It is on metal parts if you do not want the paint to easily scratch or flake off. Have you tried such as B&Q, a hardware store or even a model shop?
samtt600
#3 Posted : 03 October 2012 16:10:07
Rank: Newbie
Have tried b&q with no luck and modelzone local to me with no joy. Isn't primer from a hardware store going to be too thick?
court orchard
#4 Posted : 03 October 2012 16:20:19
There's a Games workshop in Derby where you can buy the Citadel Black spray primer and the Toy-master near us sell it too. It's what I use.
saintsman123
#5 Posted : 03 October 2012 16:48:13
i use basic carplan spray primer from my local garage, it's worked ok on my victory, san fransico2 and other models with metal parts.
corwall model boats have a metal primer, which as it's in the same section as the acrylic paints i would assume its ok for acrylics.
Come on you Jimmies
mark 2
#6 Posted : 03 October 2012 18:44:58
Hi everyone.
Yes you can use the CMB metal primer for acrylics as i have done so BigGrin.
Best regards all.
#7 Posted : 03 October 2012 19:45:48
He doesn't want to buy via the net
#8 Posted : 03 October 2012 19:53:42
If it is on the metal parts then "Red Oxide" primer from Halfords is good.. I know I go on about there sprays but I'm sure most will agree they are very good with Grey and white and even yellow primer.. they even do a flexible primer (for bumpers)
Spence
Wilfy the Sea Dog
#9 Posted : 03 October 2012 21:16:14
Hi,
Have you tried Halfords?
I use their grey primer for plastic parts, works a treat. Nice thin even coat.
Doesn't cover up detail either, I use it on most of my plastic model kits & it also works well on sealed wood.
Wilfy
extinctionjet
#10 Posted : 04 October 2012 09:58:05
I think im going to get some in Games Workshop.
(they have everything for warhammer meta/plastics and some wood accessories)
Or check ebay?
denissimo
#11 Posted : 06 October 2012 03:51:05
Remember when using different types of paint, you can get a messy reaction.
You can paint acrylic over cellulose (Carplan primer etc), but you cannot paint cellulose over acrylic as it bubbles up and cracks!
Model boats built so far:-
Billings Cutty Sark
Scratch built twin IC RC Vosper MTB.
Scratch built rc electric hybrid.
Scratch built rc IC hydrofoil (ran happily on snow as well as water!)
Plus numerous numerous RC planes.
Under construction
Sovereign of the Seas!
1200:1 HMS Victory (by Mantua)
The Battleship Yamato (seriously considering building as an RC model)
NMBROOK
#12 Posted : 07 October 2012 20:25:32
I use upol acid etch primer from halfords on metals.Its about £12 for a big aerosol but lasts for absolutely ages and can be overpainted with anything.Normal paints can flake off after time.
Hector
#13 Posted : 20 October 2012 21:26:00
Rank: Amateur level 2
Hi guys,my cannon paints arrived today but i over-looked metal primer.
In the basement i found a couple of cans i wonder if they are suitable,i have cold zinc galvanise spray wich being a steel fabricator i use every week with good results but nothing as fine as the cannons,and matt black car spray wich claims to need no undercoat.
Any help would be greatfully recieved :)
Kind regards
Rich
Tell me the truth,I shall not offend nor be offended
#14 Posted : 21 October 2012 00:38:16
BigGrin Hi Hector
the zinc spray may be on the heavy side and fill in details on the cannon also i think it may be celulose based and not an acrylic/water based spray i would go for either any halfords spray primer of any good motor factor shop primer like car plan.You can sometimes get a bad reaction if you try and mix celulose paints and acrylics so try and get an acyrlic based undercoat that will go with the acrylic paints you have
f1marshal
#15 Posted : 21 October 2012 10:48:30
I hope this helps but i use Halfords own primer in a spray can i also have the clear lacquer from them and it works ok for me
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
This page was generated in 0.206 seconds.
