 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi DaDokta Your Deck is looking very good  Keep up the good work
Joined: 04/06/2012 Posts: 19 Points: 57 Location: Pretoria (SA)
Your build is looking good, your workplace is very clean!! Built Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans
In the meantime. HMS Victory (Deagostini) 2011 Building MFV63 fishing trawler from plans. HMS Mayflower (Kit)
Wish list Still planning.
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Nice build and it could soon be in the category of a museum build. Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Thanks for your nice comments :) Greetings, Walter
Hi very nice work  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
The finshed upper gun deck after two coats of varnish:The upper half of the hull is now fully planked:DaDokta attached the following image(s): Greetings, Walter
Your Hull is looking good DaDokta
Good looking build you have there. Keep up the good work. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi shipmates! I´ve been busy cutting the upper-deck gun ports and way more so framing all the ports! What a time consuming work!DaDokta attached the following image(s): Greetings, Walter
Hi Doc, you have made great progress  good stuff, Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
You may want to put on a second, makes life a little easier when you do the 'last 10'.
Looks great.
John
Thanks for the advice John! Greetings, Walter
Excellent advice from John, I put on an additional 2 rows and it certainly made planking the last 10 rows much easier.
I finally finished the hull!!!!!!Sanding paper - here i come!!DaDokta attached the following image(s): Greetings, Walter
Joined: 02/09/2012 Posts: 81 Points: 252 Location: Kingston upon Hull
Hello DaDokta, congratulations on completing the hull planking  Cheers Chris Builds in progress: DeAgostini HMS VictoryDeAgostini McLaren MP4-23 " If it looks right then it is right "
Congratulations for closing the Hull I wish much fun sanding it
The last days have gone by with filling and sanding. This being my first experiances with wood modelling, i must say i`m very pleased with the results so far. Next step will be fitting the keel. DaDokta attached the following image(s): Greetings, Walter
its amazing how some filler and sanding can produce such a good finish. great work Come on you Jimmies
Thanks for the nice comments! Greetings, Walter
Guest (7)
