 NP m8 same happens to me at times Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
now all you need to do is get a huge magnifyer and put all the rivet and screw marks around each porthole, then make them all open and close.  good work andy Come on you Jimmies
go for safestyleuk you konw you buy one you get one free. b###y advert drives me mad Come on you Jimmies
 Rank: Pro  Groups: Registered
Joined: 27/06/2011 Posts: 110 Points: 312 Location: Glasgow
Looking excellent.....makes me slightly apprehensive about my porthole adventure coming up I smile because i have NO IDEA whats going on :)
 Hi Smuggler theres no reason to be aprehensive m8,if you use 40mm wide masking tape to transfere the portholes like i did.Just line the masking tape up with the top of the hull for the lower[hull] portholes and the top of the hangars for the upper ones.Your 1st portholes will take a lot of time as you make sure its aligned but after as you gain confidence they get easyer and faster GL with yours regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All i have now finished drilling all the holes for the port side portholes,i have added some to the hull and have some more to add from the plans i have on the hangars[i will add these later].Just the starboard side to do now,as ussual all comments and questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She is starting to get that impressive look about her with the superstructure going on Andy. Looking good
Joined: 21/04/2012 Posts: 747 Points: 2,233 Location: Tokyo, Japan
Hi Andy! Your voyage seems very satisfactory.  I'm waiting for your next sending. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Thanks Harty and Yaturo for your kind words Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have now finished adding all the lower hull portholes[pwew  ],i again used 40mm masking tape as described before to transfere them.As ussual all comments and questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have started to add the Deguasing cables to the hull but ran out of the plastic strip  so il need to obtain more to finish this off,just a few pics of progress so far.All comments/questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy! Thank you for your help in the Smuggler's topic. By the way, I have to point the location of the cables. I wrote about it in the #25 post of the "Look before -" topic. I hope you to refer to the post. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Thanks for the reminder Yaturo,i did have that in mind when i was placing the cables but forgot  to refer to your mines the offending cables have now been removed. Thanks again Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
You are welcome, Andy I'll post residual mines as early as I can. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Hi All The upper hangar floors are now painted up and placed in position,just a few pics to show this although there may be some adjustments to be made to the forward deck as Yaturo has pointed out.As always all comments/questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
looking good andy. i finally started my build, i've got the keel and ribs on, but thats all for the moment i can't start planking as i used some of the wood supplied on a different model and am waiting for cmb to get more stock. Come on you Jimmies
 Hi Saintsman Nice to hear you have started,just one thing to look out for on the planking.This is the rear step for the armour belts that are added later,the step here is almost non existant[unlike the bow step which is quite large] so you have two choices either cut and fit to obtain the step here or just plank straight across like i did then when it came to fitting the armour belt here i just measured and carved/cut back to get the corect profile to fit.I personaly found it easyer to plank straight across and fettle it to fit, but its your choice,hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Saintsman! If you start planking of the hull, I recommend you to read #4 post of my diary, "A renewed building diary in English" just once. DeGOSTINI Japan's step told us to use water for warping planks to adjust them to the shape of the hull. I think such a method is not proper. Best Regards, Yutaro. DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Guest (11)
