40 Pages «<7891011>»
#161 Posted : 28 September 2012 23:14:10
Riggers wrote:
Nice Start Mike like it Cool. As you know I'm building the Victory at the moment would you recommend putting Balsa in her bow and stern? It's my 1st wooden ship build and it must help a lot with curving the planking...
Cheers
Hi Chris thank you for the nice comment I would certainly Balsa the Bow and stern, I did it in my Victory build and Fitted balsa to the Cutty Sarks complete Hull, and The Endeavour
Kind regards
Mike
#162 Posted : 29 September 2012 00:27:10
Hi Mike,
I see your well under way with the Sovereign,great presentation,you are a real help to this forum keep it all going Mike.
Kind Regards Trev.
Riggers
#163 Posted : 29 September 2012 16:09:00
MWG wrote:
Cheers
Kind regards
Mike
Hi Mike your welcome. The pictures of all the hulls with balsa attached have given me lots of food for thought thanks for that. Have to source some balsa now and read up on how to attach it BigGrin .
Cheers
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
Sillvestra
#164 Posted : 29 September 2012 17:08:26
Hi Mike, thanks for such a useful build diary. I'm currently in the process of setting up my work space and your tools list has been a great help allowing me to create a basic tool set for the build. I'd never have thought of using tiles to keep pieces flat (was thinking of using books) so I popped into B&Q today and picked up a pair of 500mm x 500mm floor tiles for a few pounds BigGrin (other diy stores are available).
Hopefully be up and running this weekend although will have to wait 4 weeks for my next bunch of issues which will contain the stern keel piece...
Keep up the good work. Will definitely continue looking in for more hints/tips for us 1st time builders...
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
Jesus-Belzheim
#165 Posted : 30 September 2012 16:25:29
Hi Mike
That looks good with the Balsa, great Tipp ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
jonny7england
#166 Posted : 30 September 2012 18:31:05
Mike...What is the specifications of your brackets mate please? Blink
#167 Posted : 02 October 2012 12:38:56
tf64 wrote:
Hi Mike,
Kind Regards Trev.
Hi Trev Thank youBigGrin I appreciate it. Kind regards Mike
#168 Posted : 02 October 2012 12:42:03
Riggers wrote:
MWG wrote:
Cheers
Kind regards
Mike
Cheers
Hi Chris I will be giving detailed instructions on how to Balsa the entire hull, we still use PVA adhesiveBigGrin Regards Mike
#169 Posted : 02 October 2012 12:47:37
Hi Andy, I am glad you are finding the tips usefullBigGrin Regards Mike
#170 Posted : 02 October 2012 12:49:04
Jesus-Belzheim wrote:
Hi Mike
Thank you PeterBigGrin Regards Mike
#171 Posted : 02 October 2012 12:51:05
Hi Jonny, here is the spec:-
6 cm long x 6 cm high x 1.5 cm I hope this helps youBigGrin Regards Mike
#172 Posted : 03 October 2012 18:01:00
ISSUE 5 BUILD
Hi Team, not much to do this week,the plan is to assemble a further rib, and store the rest of the parts under my tile press.
This is what we received this week:-
#173 Posted : 03 October 2012 18:05:12
ISSUE 5 BUILD
next up is to cut out and sand off all the loose ash from the edges of all the parts:-
#174 Posted : 03 October 2012 18:08:07
ISSUE 5 BUILD
I then stowed parts 17, 18, and 19 in my tile press, and proceede to assemble rib 16 with 16a and 16b:-
#175 Posted : 03 October 2012 18:12:29
ISSUE 5 BUILD
then using adhesive (PVA) I fixed the parts together again using my board covered in plastic so the glue will not stick to the board.
Thats all for this weekBigGrin Thanks for looking in, questions and comments welcome.
I will leave you with a photo of my tile press filling upBlink Regards Mike
Ger C
#176 Posted : 03 October 2012 18:52:56
Hi Mike,
Looking good ss always, the tips you are giving are useful to all
#177 Posted : 03 October 2012 21:50:15
Ger C wrote:
Hi Mike,
Hi Ger, much appreciatedBigGrin Regards Mike
#178 Posted : 04 October 2012 19:48:30
Great work Mike, finding your diary very well presented, informative and very easy to follow....Cool
#179 Posted : 05 October 2012 02:07:09
Hi GD thank youBigGrin Regards Mike
Admiral Anti Spiral
#180 Posted : 05 October 2012 02:21:32
looking good mike, cant wait to see it all put together ^^
Processing - Progressing
Previous builds: HMS Victory
Guest (6)
This page was generated in 0.260 seconds.
