Hamock Netting Options
GilShapley
#1 Posted : 26 September 2012 20:45:55
I am now on issue 93.Can someone clarify which wire I should be using to connect the cranes for the hammock netting. I think it is the .5mm but not sure.
Current Build:-
#2 Posted : 26 September 2012 23:31:30
.05mm it is,you can always check uncle tom's official build,will comfirm for you.Cool
GilShapley
#3 Posted : 27 September 2012 15:06:23
Thanks for that. I thought is was the .5mm
I am painting my model so to facilitate the adhesion of the small hammock parts I am going to use my razor saw to scrib very shallow groves along the top of the rails (Where I can) My razor saw is .5mm and the hammocks are .4mm approx
This serves several purposes.
1) Leaves a clean surface for the glue to stick too
2) I can easily mark the location of each part above the pillars
3) The shallow grove gives the part more to stick too (I hope)
If you try this be very careful as the top rail is only just over 1mm thick
Current Build:-
This page was generated in 0.089 seconds.
