40 Pages «<678910>»
#141 Posted : 26 September 2012 22:02:00
ISSUE 4 BUILD
Hi Team the object of this weeks build is to assemble 2 Ribs and to fit 2 x part 12 to the Bow former.
I am concentrating on fitting the Balsa infills to the Bow and fairing that part (It is easier when it is not fitted to the rest of the ship )so it is part finished.
This is what we received this week:-
#142 Posted : 26 September 2012 22:04:50
ISSUE 4 BUILD
And the parts we received ( cut from the fret ):-
#143 Posted : 26 September 2012 22:08:41
ISSUE 4 BUILD
I cleaned off the ash and assembled the ribs 13 and 15, I used my board with the plastic fitted to glue all the parts with PVA, and when the glue was dry I placed the ribs in my tile sandwichBigGrin :-
#144 Posted : 26 September 2012 22:13:21
ISSUE 4 BUILD
Next I fitted the 2 x parts to the Bow former, and fitted pieces of Balsa between parts 11 and 12 on both sides and also on the end of part 12 both sides:-
#145 Posted : 26 September 2012 22:17:18
ISSUE 4 BUILD
Now I began to shape the Balsa with a large file and sand paper block:-
#146 Posted : 26 September 2012 22:21:12
ISSUE 4 BUILD
Near the end now, I use my preffered filler to fill in any undulations prior to Fairing the piece, which I do when it is dry:-
#147 Posted : 26 September 2012 22:24:48
ISSUE 4 BUILD
Well Team thats it for this session, thank you for looking in, as usual questions and comments are welcome.
I leave you as usual with the parts sanded and finished for now.
Kind Regards Mike
#148 Posted : 26 September 2012 22:36:36
Nice work Mike, hope with your detailed instructions I can get as good a result... thanks for the pics....
mark 2
#149 Posted : 27 September 2012 07:05:13
Hi mike.
I must say that i too am following your build BigGrin as you and Mr T are the masters of ship building and a lot can be learnt from you both.
Best regards.
Blackspear
#150 Posted : 27 September 2012 07:25:54
The balsa work is looking good there Mike, I have just received Parts 4 & 5 so I'll be having a fun weekend doing my first ever balsa work.
Craig
#151 Posted : 27 September 2012 12:04:19
Thank you GDBigGrin Regards Mike
#152 Posted : 27 September 2012 12:05:20
Craig
Hi Craig thank you for the commentsBigGrin Regards Mike
#153 Posted : 27 September 2012 12:16:40
mark 2 wrote:
Hi mike.
Best regards.
Hi Mark thank you for the compliment, but I am not a master, Mr T has probably forgotten more than I know, about model making, plus there are other members far more qualified than me. But I appreciate your sentiments.
Just as an aside Mark the way I am constucting the build is my interpretation please be aware while following what I do, that changes could be made by Deag that may affect what I am doing, and could affect your build. just giving you the heads up.But I will help you through should they arise.
Kind regards
Mike
IAN
#154 Posted : 27 September 2012 15:44:04
Hi Mike..
I am following your balsa fill with interest, I might have the confidence to have a go on the Soverein build.
Great work again.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#155 Posted : 27 September 2012 15:59:49
Hi mike.
Looking good mate, see the balsa wood fillets are out again, will you be filletting all the bottom of the hull. Ian Cool
#156 Posted : 27 September 2012 18:10:18
IAN wrote:
Hi Mike..
Great work again.
Best regards,
Ian
Hi Ian you can do it,I have every confidence in youBigGrin Regards Mike
#157 Posted : 27 September 2012 18:11:59
ian smith wrote:
Hi mike.
Hi Ian thank you. yes I will all the hullBlink it makes planking so much easierBigGrin Regards Mike
#158 Posted : 28 September 2012 16:00:19
looking forward to seeing more of your build diary and modifications Ian. BigGrin
#159 Posted : 28 September 2012 20:44:51
Hi Ian thank you for thatBigGrin Regards Mike
Riggers
#160 Posted : 28 September 2012 22:12:38
Nice Start Mike like it Cool. As you know I'm building the Victory at the moment would you recommend putting Balsa in her bow and stern? It's my 1st wooden ship build and it must help a lot with curving the planking...
Cheers
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
40 Pages «<678910>»
This page was generated in 0.267 seconds.
